If make some changes on my locally cloned project, do I have to build the entire project again ?
Yes, your compiler should be able to figure out which code parts need updates. So it depends on what you changed.
I am using windows, so MS Visual Studio 15 (2017) shall do the job, right ?
Yes, but you will have to run some commandline arguments, as mentioned in the readme.
(2019-03-12, 01:07)Razze Wrote: [ -> ]Yes, but you will have to run some commandline arguments, as mentioned in the readme.
Thanks for your help.
(2020-11-16, 09:58)jibranahmed Wrote: [ -> ]Thanks for your help.
We have little patience with forum visitors posting nonsense in old threads on our forum.
I suggest you stick to post useful and constructive messages if you do not want to have your stay here suddenly stopped.
