2020-05-10, 17:42
(2020-05-09, 22:44)Johnny1982fd Wrote: [ -> ]@Johnny1982fd , I did not implement an option to disable showing duration, and, unfortunately, I will not. The number of unwatched episodes can be disabled, go to Settings, Amber Settings, Media Views: Hide Unwatched Episodes Marks.(2020-04-17, 19:10)bsoriano Wrote: [ -> ](2020-04-17, 16:07)Johnny1982fd Wrote: [ -> ]Hi @bsoriano@Johnny1982fd , thanks! As of right now, you cannot disable the showing of duration for tv shows and movies, or the showing of unwatched episodes for tv shows. You can disable the showing of the rating (your last screenshot), by going to Settings, Amber Settings, Media Views, and set "Hide Second Label in List Views" to Yes.
Thanks for the last update. Looks really cool
Pls have a look here. I dont found an option to change these things. ANy ideas ?
https://imgur.com/a/pnwKDkm
Regards,
Bart
Hi @bsoriano
sorry, i must ask again. Did you implement an option to disable on tv shows the duration?
First picure left side:
In case of yes, it doesnt work with latest version.
Can you check this pls ?
2.) Now i understand what means with "Blur". But it doesnt work with my PI4. I got always the normal cover.
3.) Questions regarding Big List, Big List 2
Line 31960: Big List --> Translate this to "Große Liste"
Line 31999: BigList --> Translate this to " Große Liste 2"
Line 31152: Disable BigList View --> Translate this to "Große Liste 2-Ansicht deaktivieren"
But i didnt found an entry like "Disable Big List View". Is that right and your attention or is this missing?
Thanks Bart!
I apologize for the confusion between 31960 and 31999. It should just be "BigList", which is 31999. I will remove 31960 in a future update. Given this, waht is the correct translation for 31152?
Thank you for continuing to work on the translation.
Regards,
Bart
