(2020-06-05, 00:40)bsoriano Wrote: [ -> ]@crazyhands911 , please check out Amber 3.2.87. I added an option for a more mouse-freiendly alphabet strip. While you can't get to it just using a mouse, you can press right to get to it and then with the mouse you can click on a letter to jump to that letter.
Also, I have added an option for the fanart view focus to be more centered, starting in the fifth position for posters (this does not apply for music or other square icon items).
Please test and let me know what you think. Thanks.
Regards,
Bart
All hail @
bsoriano !!!
I ask about a few tweaks and less than a week he has solid fixes for in place. Amazing work Bart!
First, I was surprised that it didn't auto-update. I'm new to the repository stuff. I assumed that by getting the repository from github and having auto-update checked, the skin would update whenever you put out new updates or I could at least force it to update somehow from within Kodi. I just went back to the source and downloaded the zip file for the update and installed from zip. If I should do something differently there, please let me know.
The shift to the right for the Fanart View is perfect after making the change, I had already forgot I was supposed to be testing that, because it just felt so natural to me for it be in that position. So mark that little guy resolved.
Next, the enlarged Artwork selector. This is amazing and exactly what I needed to better assist me with selecting some of those pesky anime poster that have hard to read text to ensure I'm getting an English translated version or even the correct title and not just some other text. From my quick 5 minute test of the new build, I did notice that some artwork appeared very crisp in the enlarged view, while some artwork seemed very fuzzy, both fanart and posters alike.
I did select a few of the very fuzzy items to see what they looked like after I selected them, and in the Fanart view, they looked fine.
Oddly, if I go back into the artwork selector, the previously fuzzy image that is now set as Current Art looks just fine, but the remote image still looks fuzzy if I go back down the list to the image that I selected.
Oddly, if I go back into the artwork selector, the previously fuzzy image that is now set as Current Art looks just fine, but the remote image still looks fuzzy if I go back down to the image that I selected.
While I can certainly make due, knowing that the image likely is better than previewed, there might be some bugs to be worked out on how they rendered in some instances. Again, not all artwork is fuzzy, only some. Many are perfectly clear and crisp to start with.
Mouse friendly alphabet strip. It gained some functionality, but also lost some. I could previously take my mouse to the bottom of the screen and the alphabet strip would come up and I could hover over the different letters, just not click on any of them. With the tweak you made, I can click on the letter and it will jump there now, but the strip won't appear by simply hovering my mouse at the bottom of the screen. I do have to use a keyboard for the down key for the strip to appear and then I can click on a letter, just like you described in the update notes. Hopefully this won't be much of an issue once I get my iPazzPort keyboard controller with integrated track pad and IR learning in the mail. I'm eagerly awaiting its arrival, as it will greatly assist in navigating Kodi, as well as hopefully removing the need for my TV and AV receiver remotes, if the IR learning function actually works as described.
These will be some great additions to the skin and I really appreciate your openness to look into ideas and try to find ways to improve the skin. Again, let me know if I should be doing something other than watching this thread to get all of the great future updates, or if I'm missing something in the way I installed stuff to get them automatically.
