Hello all,
I have uploaded versions 3.2.107 (Leia) and 3.3.107 (Matrix) to GitHub and the Amber repos. The main changes are:
1. Add 8K, HDR/SDR, video bit dpeth, Atmos, DTS-X flags and complete video source flags (webdl, hdtv,sdtv). Thanks to @
newbii for creating the flags. With the exception of Atmos, which Kodi will pick up correctly from your NFO or the video files themselves, for all of these new flags to show up, you need to name your files accordingly. Amber will look for the following in order to show the flags:
a. You need to include
8k in the name of the file for the 8K flag to show up.
b. You need to include
hdr n the name of the file for the HDR flag to show up.
c. You need to include
sdr n the name of the file for the SDR flag to show up. Please note that this was done this way since the majority of the files are most likely sdr, and most people would want an indication of HDR, not of SDR. If you do want the SDR flag to show up, include sdr in the file name.
d. You need to include
8bit or
8-bit in the file name for the 8-bit flag to show up. Again, like SDR, most files have an 8-bit video bit depth. It will not be shown by default.
e. You need to include
10bit or
10-bit in the file name for the 10-bit flag to show up.
f. You need to include
12bit or
12-bit in the file name for the 12-bit flag to show up.
g. You can include
atmos in the file name for the Dolby Atmos flag to show up.
h. You need to include
dtsx or
dts-x in the file name for the DTS-X flag to show up.
i. You need to include
webdl or
web-dl or
webrip in the file name for the WebDL flag to show up.
j. You nedd to include
pdtv,
sdtv or
sd-tv in the file name for the SDTV flag to show up.
k. You need to include
hdtv or
hd-tv in the file name for the HDTV flag to show up.
l. a. You can include
4k in the name of the file for the 4K flag to show up.
The HDR/SDR and video bit depth flags are not shown by default. You need to activate a new skin setting for them to show up. You can find the skin setting here:
Some examples that show the file naming and how the flags show up:
- File name is back to the future part iii (1990).hdr.10bit.mkv
Please note that in the example above, neither 4k nor atmos are included in the file name. Kodi picks these up automatically and shows the correct flag. You can include them in the file name if you want to make sure that they appear.
- File name is despicable me 3 (2017).dtsx.hdr.10bit.mkv
- File name is 20000 leagues under the sea (1955).webdl.mkv
2. Add option to show the file name instead of the title in the Icons view. You can enable this option in any Icons view by going to the sideblade and activating it from there, as shown here:
And it looks like this:
3. Fix for transparent background being shown in the music OSD
4. Fix for not being able to close the lyrics dialog.
As usual, please download, test, and let me know if you find any issues. Thanks.
Regards,
Bart
