Hello all,
I have uploaded versions 3.2.127 (Leia) and 3.4.14 (Matrix) to GitHub and the Amber repos. After this version, all new functionality will go to the Matrix version, and I will only do bug fixes to the Leia version.
Highlights of the version:
1. Option for left-aligning the vertical menu item text. You can find the option here:
2. Improvements to local search select dialog. When you have "Show Only Local Info" and "Search only in Local Database" enabled, and you click on a cast item in the video info window, you will get a dialog like this now:
As you can see, I have added media info to each item, used the poster instead of the icon, and added media flags.
3. Improvements for normal lyrics. I have reduced the font size of normal lyrics and made it so that up to 10 lyrics lines can be shown at the same time. It looks like this:
4. Option to Dim background when showing lyrics. This was always being done before. Now it is optional. It is important to note that the default is NOT to dim the background when showing lyrics. You can find the new setting here:
5. Option to show the seek bar at the start of playback. Now you have the option to show the seek bar at the start of video playback. You can choose how long to show the seek bar. It is important to note that, on Leia, if you have enabled to play the next video automatically and activate this new setting, the seek bar will show for about two seconds when the next video starts, no matter what interval you choose in Amber settings. I will not be able to change or fix that. The setting works as expected in Matrix. You can find the new setting here:
6. Option to show media info with seek bar. If you enable this new setting, Amber will show basic media info with the seek bar. You can find the new setting here:
It looks like this:
7. Alternate layout for Favourites. I have added an alternate layout for favourites, which resembles the Big List view. Please do not ask me to do any other alternative layouts for favourites, as I will not do any more. You can find the new setting here:
And it looks like this (it is important to note that the only info a skinner has for each favourite is title and icon):
8. Add Trakt rating in video info dialog. If you have this rating loaded in your db, Amber will now show it in the video info dialog. It important to not that I have not added yet the option to disable showing this rating. It looks like this:
9. Single column option for Simple List view. You can now choose to only show one column when using Simple List view. The setting is here:
And the result is this:
Finally, there are multiple other smaller features and fixes.
Please test thoroughly and let me know if you find any issues. Thanks!
Regards,
Bart
