(2019-09-05, 20:01)Bassam909 Wrote: [ -> ] (2019-09-05, 17:15)bsoriano Wrote: [ -> ] (2019-09-05, 17:11)Bassam909 Wrote: [ -> ]Hello there, I'm totally new to using Kodi, I figured Amber skin is best for my needs, To be honest I'm sort of lost getting through with the customization, I have a good idea of what I want to achive but I'm at lost in the settings menu. Is there a user guide or an updated walk through on this skin? I'd love to make the best of it.
Best Regards
@Bassam909, unfortunately, there is no user guide or updated walk through at this time. I will put this in my To-Do list for the skin, as I can understand the need for it.
In the mean time, please post any question you have here, and I will do my best to answer them, including screenshots that could help you. Also, if you can post here a description of what you want to achieve, I will do my best to explain how (if) it can be done with Amber. Thanks.
Regards,
Bart
if I have a folder contains courses, is it possible to make list with each course into an album or playlist and have cover artwork for that each one?
is it possible to customize Kodi Amber Skin like you would with do in iTunes, meaning create menus and custom albums for video content that is not movies or tv shows just mp4 with meta data.
In the customize home menu and shelves, “Change Action” what this is?
Warm Regards
Bassam909 , you can create a smart playlist based on a folder, as explained here:
https://kodi.wiki/view/Smart_playlists, or you could create a video node, as @
DarrenHill mentioned in the previous post. You can then in Amber assign the playlist as the item for a menu item.
If you want cover artwork as well as other meta data, you can create a NFO file (
https://kodi.wiki/view/NFO_files) for each one of your videos, that includes information about what is, for example, the poster or fanart for each video, as well as the plot, etc.
I would then suggest to create a video source (
https://kodi.wiki/view/Adding_video_sources), and using the "local information only" option where it asks "Choose information provider", so that Kodi knows that it will look for an NFO file next to the video for information on it, instead of going online to look for it.
Even if your mp4 files contain metadata, if they are not movies, tv shows or music videos which show up in Themoviedb.org, imdb.com, thetvdb.com or theaudiodb.com, Kodi will not load that metadata. That is why I am suggesting to you to create NFO files. You would need to create one for each file you have. This can be tedious, but in a lot of cases is the only way to get Kodi to show the data you want about your videos.
You can use music video as the type of content for your video source, so that your videos do not show up in your movies or tv shows lists.
Change Action allows you to choose something else as the item for a menu item. In your case, after you have created your video smart playlist(s), when you add a menu item, and press "Choose Item for Menu", you will find your playlist under "Video Library", and then "Playlist", and there you should see your playlist. When asked, select if you want to Display the playlist or Play it.
I hope this information is useful.
Regards,
Bart
