(2019-09-21, 17:27)bsoriano Wrote: [ -> ] (2019-09-21, 13:52)edjalmo Wrote: [ -> ] (2019-09-20, 22:03)bsoriano Wrote: [ -> ]@edjalmo , I think I fixed the cast issue, please test the latest from Git. I had not noticed, because out of 629 tv shows, I only have 1 that has no cast.
I am not seeing the issue with the plot size in the person info page. Could you please send me a screenshot? Thanks.
@jurialmunkey implemented choosing from a list of people, since there are many actors,directors, writers, etc. with the same name in TMDb. He also implemented separating the directors and writers when doing online searches.
I am sorry I had forgotten about the recently added episodes playlist. I fixed this now.
Regards,
Bart
I personally don't like this way of you show when has no cast. Of course is better than previous, and fixed the bug. You can't just skip cast when they have 0 persons? This way, in this cases the first thing will be the seasons.
Also, I noticed that only seasons have a frame for text with a smaller size. I think will show better if you put the same frame size as the others for seasons text too (and center the text on the y axis).
Another thing about this is that when we navegate into "other movies directed by", "similar", "more from 2019", etc, and stop in one of this when we go to other movie/tv show they will start in the section that we stoped before, and not in cast.
Check out TMDb plot for Steve Buscemi:
@edjalmo , please check the latest from Git. I increased the size of the bio textbox in person info, and I also made the text for the Seasons info list consistent with the other info lists in video info.
I think I also solved the going back to the cast when you switch movies/tv shows. Please test and let me know. Thanks.
Regards,
Bart
Thank you!
About tv show without cast, I checked again and now it show seasons, but in other time it was showing the cast space with that image you show when have a shelf without nothing. If it happend again I tell you.
The going back to cast worked here, this will not work if I back pressing "esc".
______________________________________________________
I have another suggestion and will explain the use case.
In settings we have an option to select what show in custom list and an option to show online TMDb info. I use Kodi in a RPi 3, if I enable the option to show online info I will get always a temperature alert because my Pi can't handle with the request of custom list online, so I made this disable here. However I wish to see sometimes online infos about directors or writers, but the way it are I can't. What I wish, and this is the request, is have one option in custom list to show online info, and the other option (out custom list) will work for the rest (for when I click in a director, writer, genre, etc (and if this is enable will show a pop up asking if the search will be local or online search, like is already). This way I, and other people that use low power device will not get warnings and be able to see some infos online.
Exist too another things that is not classified, in my opinion, in none of the options, that are budgets, revenue, RT critics consensus, etc. I like things, but again Pi can't handler with much online requests (since this is less request maybe work, but don't know).
An ideia that come to my mind is have and option for TMDb online info that is something like "use as a button" (this option will came when we click in show TMDb online info). This option enable a new button in video info page (like extended info) and when we click on it in a movie will get the TMDb online info about. Directors, writers, etc, will be clickable to see online info, the same way (without clicking in extended info) if this is enable. Actually this is like it was before the new plugin.
Or may have another solution.
Hope this be a useful thing not just for me!
Another thing that I noticed is if we are in TMDb helper plugin and click "I" in one person, the page that load is in video info page style, and not in person info.
