2020-03-28, 00:28
(2020-03-27, 17:02)bsoriano Wrote: [ -> ](2020-03-27, 04:58)TheRealDeadMan Wrote: [ -> ]@TheRealDeadMan , thanks for reporting this. I made a mistake with the Kodi version in the repo. I have fixed it now. Version 1.0.1 of the repo will work correctly. Install the Amber Matrix repo version 1.0.1 and update Amber from there. Please let me know if you still run into any issue. Thanks.(2020-03-27, 00:51)bsoriano Wrote: [ -> ]@TheRealDeadMan , I have updated the Amber Matrix repo (https://github.com/bartolomesoriano/repo.amber.matrix) with the most up-to-date version of Amber. Now the version in the Amber Matrix repo is 3.3.52, which is on par with the 3.2.52 version for Leia. Please install the Amber Matrix repo and keep Amber for Matrix up to date that way. Thanks.
Regards,
Bart
Thanks for the updates. But I couldn't get the repo to connect. Tried to install the skin by downloading from the repository as well.
My Current Amber version is 3.3.23 from the Kodi repo.
Install repository.amber.matrix-1.0.0.zip:
2020-03-26 20:02:27.466 T:2137 NOTICE: CAddonMgr::FindAddons: repository.amber.matrix v1.0.0 installed
On screen error when updating From Repo:
Amber Repository - Matrix
Could not connect to repository
Scroll across the screen - AMBER The dependency on xbmc.python version 2.24.0 could not be satisfied.
The listing in the Install From Repo menu does show up though, then tells me there are no updates.
Trying to install the downloaded skin - skin.amber-3.3.52.zip:
2020-03-26 20:03:20.342 T:2185 ERROR: GetDirectory - Error getting addons://repository.amber.matrix/
2020-03-26 20:03:20.358 T:1400 ERROR: CGUIMediaWindow::GetDirectory(addons://repository.amber.matrix/) failed
2020-03-26 20:09:34.797 T:2244 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
2020-03-26 20:10:47.074 T:2242 ERROR: Previous line repeats 3 times.
2020-03-26 20:10:47.074 T:2242 ERROR: Rename - Error renaming file /storage/.kodi/addons/repository.amber.matrix
2020-03-26 20:10:47.074 T:2242 ERROR: Failed to move old addon files from '/storage/.kodi/addons/repository.amber.matrix' to '/storage/.kodi/addons/temp/5ca392c8-61fa-47df-9e2a-b83d04c05474'
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.module.musicbrainz' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.module.simplecache' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.module.thetvdb' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.module.beautifulsoup' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.module.metadatautils' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: Add-on 'script.skin.helper.widgets' is not compatible with Kodi
2020-03-26 20:12:25.074 T:2242 ERROR: CAddonInstallJob[skin.amber]: The dependency on xbmc.python version 2.24.0 could not be satisfied.
If this isn't good enough, just let me know what you need to see
Regards,
Bart
@bsoriano
Similar problems loading some plugins.
I do have some installed related to the errors shown (versions further down). I will check the Kodi addons/matrix site and look around the forum to see if there are some newer versions.
2020-03-27 16:08:47.831 T:1764 ERROR: CAddonInstallJob[skin.amber]: The dependency on xbmc.python version 2.24.0 could not be satisfied.
2020-03-27 16:09:00.867 T:1146 ERROR: ExecuteAsync - Not executing non-existing script plugin.video.themoviedb.helper
2020-03-27 16:09:00.868 T:1146 ERROR: ExecuteAsync - Not executing non-existing script script.skinshortcuts
2020-03-27 16:09:00.868 T:1146 ERROR: ExecuteAsync - Not executing non-existing script script.skin.info.service
2020-03-27 16:09:00.874 T:1765 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
2020-03-27 16:10:30.559 T:1146 ERROR: Previous line repeats 5 times.
2020-03-27 16:10:30.560 T:1146 ERROR: ExecuteAsync - Not executing non-existing script plugin.video.themoviedb.helper
2020-03-27 16:10:30.560 T:1146 ERROR: ExecuteAsync - Not executing non-existing script script.skinshortcuts
2020-03-27 16:10:30.560 T:1146 ERROR: ExecuteAsync - Not executing non-existing script script.skin.info.service
2020-03-27 16:10:30.569 T:1765 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
2020-03-27 16:11:32.261 T:1764 ERROR: Previous line repeats 2 times.
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.module.musicbrainz' is not compatible with Kodi
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.module.simplecache' is not compatible with Kodi
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.module.thetvdb' is not compatible with Kodi
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.module.beautifulsoup' is not compatible with Kodi
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.module.metadatautils' is not compatible with Kodi
2020-03-27 16:11:32.261 T:1764 ERROR: Add-on 'script.skin.helper.widgets' is not compatible with Kodi
2020-03-27 16:11:32.262 T:1764 ERROR: CAddonInstallJob[skin.amber]: The dependency on xbmc.python version 2.24.0 could not be satisfied.
My installed versions:
NOTICE: CAddonMgr::FindAddons: plugin.video.themoviedb.helper v2.2.25 installed
NOTICE: CAddonMgr::FindAddons: script.skinshortcuts v1.1.0 installed
NOTICE: CAddonMgr::FindAddons: script.skin.info.service v1.0.7 installed
Thanks for the Repo 1.0.1 update
