2019-04-26, 06:02
I would like to point out one thing though and that is about the separators used between genre, duration and year. Instead of using |, it would be better if you used a custom-designed separator that would look lighter.
(2019-04-26, 06:00)VikkiXavier Wrote: [ -> ](2019-04-24, 20:12)Arcanthur Wrote: [ -> ]
Wow. 2400 movies!! Are all those stored in your hard drive or do you use some kind of cloud storage? Impressive.
(2019-04-26, 16:35)zacharisharris Wrote: [ -> ]Any ETAs on another release?
Στάλθηκε από το MI MAX 3 μου χρησιμοποιώντας Tapatalk
(2019-05-01, 19:45)Arcanthur Wrote: [ -> ]Revision to the last post, slight resize on the posters and a few other elements so things line up better. Probably just my OCD, but it bothered me lol
<bordertexture border="20" colordiffuse="black">diffuse/poster_shadow.png</bordertexture>
(2019-05-01, 20:21)cartman.dos Wrote: [ -> ](2019-05-01, 19:45)Arcanthur Wrote: [ -> ]
looking great!
have you considered using a shadow img diffuse for the widget pics? so it'll blend better on the bg?
like for posters i think titan has poster shadow img in media dir so you could test it by adding:
to the widget's img control.Code:<bordertexture border="20" colordiffuse="black">diffuse/poster_shadow.png</bordertexture>
(2019-05-01, 21:48)Arcanthur Wrote: [ -> ]Sure, you'll need to add a progress control, with info tag set to 'ListItem.PercentPlayed'(2019-05-01, 20:21)cartman.dos Wrote: [ -> ](2019-05-01, 19:45)Arcanthur Wrote: [ -> ]
looking great!
Thanks! I was playing with adding a shadow, but I was having issues with the shadow showing up before the poster when the control was scrolling. I was trying it with a shadow image placed under the thumb and it caused issues. This works perfectly, it's subtle but it looks nice.
I'm still playing with the look of the watched/in progress overlays.
If I wanted an actual progress bar to show percentage watched, where would I start with that?
<control type="progress">
<description>progress bar</description>
<width>bla</width>
<height>bla</height>
<texturebg colordiffuse="cc515151" border="0">colors/color_white.png</texturebg>
<lefttexture/>
<midtexture colordiffuse="$INFO[Skin.String(OSDProgressBarColor)]" border="4">colors/color_white.png</midtexture>
<righttexture/>
<info>ListItem.PercentPlayed</info>
</control>
(2019-05-02, 22:41)Arcanthur Wrote: [ -> ]@cartman.dos thanks! Here's the result:
So yesterday Kodi crashed while refreshing the skin and somehow my IncludesHomeWidgets.xml file blanked out (0 byte file), I ended up losing a day of work. So I'm also in the process of going back and redoing that work. Ugggghhh
(2019-05-03, 14:13)cartman.dos Wrote: [ -> ](2019-05-02, 22:41)Arcanthur Wrote: [ -> ]
Been there. Really the best practice would be to use a cloud-base service, like github/gitlab.
And push every change you make, it'll make it easier to have online backup and keep track of everything, revert changes, document progress...
about the changes you've done, they're looking good, Don't u think tho it'll look better if it's aligned to the img's bottom and perhaps full width of the img?
Also, for pvr you need listitem.progress in info tag if you've got such widget.
Really hope you'll transition it to Leia, most of the fixes for Leia for titan are already there anyway in my skin if you'll ever need a reference.
