2019-03-18, 08:03
I started work on a MOD for Titan recently, as I'm currently using Krypton with DSPlayer so I can use MadVR for proper 4K HDR support, and I wanted a skin to suit my needs/taste. I'm using the Colorbox script to blur fanart background in the view types, and I'm only focusing on 2-3 views as that's all I really use anyway. I use Plex as a back end to organize and sort my libraries, so I'm using with with the KodiPlexConnect add-on.
*EDIT* Pre Alpha available.
**A note before you install this.**
This makes use of the skin backup service in order to change the default settings of the skin, and as such I recommend installing this on a portable build before moving it to your primary installation. With that said, I am not responsible if you mess up your primary build.
Kypton only for now (I use the Kypton-DS branch)
Leia will come once the skin is more feature complete
Install the scripts and resources first
Next install the skin
Then, in skin settings go to:
Slim List
Poster Shift
Big Panel
Panel Square
*KRYPTON ONLY* Download Skin Here *KRYPTON ONLY*
Found a problem with the colorbox script code as I was rushing to get this published. The fix is simple and I will fix in on the next release. For now this is all that is required to fix:
Startup.xml
Replace line 15 with this:
<onload>RunScript(script.colorbox.aesir,daemon=True)</onload>
The screenshots below are for the next version that will release in the coming weeks:
- Color Themes>Manage Color Themes>Select Aesir
- Backup and Restore>Restore the Skin Settings>Navigate to settings backup
Slim List
Poster Shift
Big Panel
Panel Square
Startup.xml
