Full Version: Support for the add-on Special Features
It would be nice if Amber would support this add-on with a button that shows up next to Trailer if there are a folder called Extras.
Add-on:Special_Features (wiki)
(2019-03-20, 10:25)peanut Wrote: [ -> ]It would be nice if Amber would support this add-on with a button that shows up next to Trailer if there are a folder called Extras.
 @peanut , this looks easy to integrate, and it looks like previous versions of Amber supported this.  I will add it to my To-Do list.  Thanks for bringing this up.
Regards,
Bart
Added on Git.  Please download Amber for Leia as stated here: https://forum.kodi.tv/showthread.php?tid=342130.  please test and let me know if any issues.  Thanks.
Regards,
Bart
I'm sorry to say that I can't see that it works.
(2019-03-23, 17:16)peanut Wrote: [ -> ]I'm sorry to say that I can't see that it works.
 Did you install Amber for Leia from GitHub as mentioned in the Amber for Leia thread? It will only work on Leia.  I tested a couple of movies with an "Extras" folder with bonus material, and the button "Special Features" showed up in the info dialog.
Did you set "Enable Special Features" to Yes in the Advanced options in Amber Settings (submenu of Settings)? I think that I neglected to mention that it needs to be enabled in Amber Settings.
Please let me know.  Thanks.
Regards,
Bart
IT WORKS! Thank you.
(2019-03-23, 20:02)peanut Wrote: [ -> ]IT WORKS! Thank you.
Thank you for confirming!
Regards,
Bart
