Full Version: Kodi 18.1 SSL not working
I have kodi set to use port 8081 in its prefs, and also have ssl enabled.
This is what I get when trying to connect to that port using ssl:
2019-03-20 15:15:04.968 T:139816779884288   DEBUG: CWebServer[8081]: request received for /
2019-03-20 15:15:05.035 T:139815362205440   DEBUG: CWebServer[8081]: request received for c����;X:~�o
2019-03-20 15:15:05.035 T:139815362205440   DEBUG: CWebServer [MHD]: Received malformed line (no colon). Closing connection.
2019-03-20 15:15:05.035 T:139815362205440   DEBUG: CWebServer [MHD]: Error processing request (HTTP response code is 400 (`<html><head><title>Request malformed</title></head><body>Your HTTP request was syntactically incorrect.</body></html>
2019-03-20 15:15:05.035 T:139815362205440   DEBUG: CWebServer [MHD]: Connection was closed while sending response headers.
2019-03-20 15:15:05.071 T:139815404168960   DEBUG: CecLogMessage - >> 80:8f
2019-03-20 15:15:05.184 T:139815404168960   DEBUG: CecLogMessage - >> 08:90:00
2019-03-20 15:15:06.032 T:139815362205440   DEBUG: CWebServer[8081]: request received for /
I've tried all of the ports listed from here with the same results. I only have non-ssl http access on port 8081.
sudo ss -tulpn | grep kodi
udp   UNCONN   0        0                                              *:9777                     *:*          usersSad("kodi-gbm",pid=29765,fd=73))
tcp   LISTEN   0        5                                      127.0.0.1:38925              0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=57))
tcp   LISTEN   0        5                                      127.0.0.1:54829              0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=77))
tcp   LISTEN   0        5                                      127.0.0.1:51727              0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=54))
tcp   LISTEN   0        128                                      0.0.0.0:8081               0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=70))
tcp   LISTEN   0        5                                      127.0.0.1:52307              0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=75))
tcp   LISTEN   0        10                                       0.0.0.0:9090               0.0.0.0:*          usersSad("kodi-gbm",pid=29765,fd=71))
tcp   LISTEN   0        128                                         [::]:8081                  [::]:*          usersSad("kodi-gbm",pid=29765,fd=69))
tcp   LISTEN   0        10                                          [::]:9090                  [::]:*          usersSad("kodi-gbm",pid=29765,fd=72))
Logs:
http://paste.ubuntu.com/p/Nthr5f8cp2/
