hello all,
new to kodi so this may seem a little dumb ... but I can't get the NASA plugin from the Kodi repo to work and just wondering what I'm doing wrong.
I found ealier on that the VideoPlayer InputStream ... 'RTMP Input' was not present so I found, installed and enabled it .. but it still doesn't work.
I've uninstalled & re-installed the NASA plugin several times ... to no avail. (also re-booted the box each time
'Using a 'Smart TV Box' with Kodi 18.1 pre-installed.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I am afraid this is indeed the case. Please read the forum rules on
banned add-ons (wiki).
Assistance can only be provided if the system is free of those types of repos/add-ons.
Folks,
I'm having the same problem running Kodi 17.6 on a Raspberry Pi. Two almost identical setups give same error.
Restarted Kodi to clear log file then between 12:17 to 12:19 selected Video - add-ons - NASA - livestreams - urthecast HD then got the following;
One of more items failed to play, check log.
https://paste.kodi.tv/adejilifim.kodi
Any suggestions appreciated.
Geffers
Similar comment unfortunately (albeit on a smaller scale).
Super repo is a
banned addon (wiki) due to some of the junk it contains that violates our
piracy policy (wiki). It's also a massive security hole due to how much it contains that duplicates stuff in the official repo but without any of our careful checks and validations (ie it can easily be a route to malware that impersonates legitimate addons and installs just by using a higher version number than something you already have installed from another legit source including our own official repo).
I would strongly suggest that you remove it from your system.
