2019-03-25, 02:58
Sometimes a movie is remade (updated). Sometimes it's just a coincidence two movies share the same exact name. iTunes stores them in the same folder, and appends a number to the filename, but tinyMediaManager only lists one of them. For example, there are THREE movies in the same franchise with the same title: "Halloween". The original in 1978, the reboot in 2007, and 2018 conclusion which ignores all the films between 1979-2017. It would be nice if tMM could pull the years from the metadata to ensure each is listed correctly, and separately. I always run my movies through Subler (you can do this with protected movies purchased from iTunes or Amazon, or any others presumably), so I have the correct information in each movie's metadata.
Otherwise, it's a great program. Wish creating export rules was easier, but so far it's good enough.
