(2019-05-21, 01:57)bennyhanna Wrote: [ -> ]Arielle Kebbler
This is Arielle Kebbel, right? (not Arielle
Kebbler)
All new added to the database.
(2019-05-22, 20:10)rschiks Wrote: [ -> ]This is Arielle Kebbel, right? (not Arielle Kebbler)
rschiks
I advise you to refer to the source of the addon and not the postings. For all postings that were not made by @
manfeed or @
Captain_Pike , i often have to adjust the resolution and cropping... and other editing thats fitting to "some kind of conventions" described on first post.
So far, all images have now the image height of 1000 pixels and are cut pretty tight. In every case the addon resource content, not in every case the posting content.
I just want to say that you will otherwise have some "outliers".
But in the end, you can handle it the way you want.
(2019-05-22, 20:56)chrissix Wrote: [ -> ] (2019-05-22, 20:10)rschiks Wrote: [ -> ]This is Arielle Kebbel, right? (not Arielle Kebbler)
@rschiks
I advise you to refer to the source of the addon and not the postings. For all postings that were not made by @manfeed or @Captain_Pike , i often have to adjust the resolution and cropping... and other editing thats fitting to "some kind of conventions" described on first post.
Ah, I see.
If others post images I will check if it’s according the guidelines, if not, I will skip it.
