Hi @"chrissix"
Thank you for addon again. I have renamed the actresses that have special characters to proper spelling but they are not showing?
The actresses without special characters display fine. Anything i need to check?
Also i see the deviantart link is latest updated. Is there way to batch download them all from there. The links on first post and repo isn't fully updated.
Thanks to @
manfeed also much appreciated
the_bo , as described in
post#1 the simplest solution at the moment is to
download addon manually, extract and just copy paste all images into the already installed addon folder.
On a windows machine should be C:\Users\YourUser\AppData\Roaming\Kodi\addons\resource.images.actorart\resources
If your AppData folder is hidden, unhide or just type appdata and push enter after C:\Users\YourUser\
In post #1 there are also additional download links if you want customize or play around yourself with the recourse images.
You have all collected there, but great thanks for also visiting the
deviantArt project page
