Full Version: Audio delay ~200ms when "Adjust display refresh rate" is on
Greetings,
I'm on LibreELEC (x86_64) 9.1 , Kodi 18.1 . Hardware: Intel NUC7i5BNK, i5-7260u .
I am having "Adjust display refresh rate" set to start/stop because the video stutters if not set properly.
I've moved to Kodi 18.1 just few weeks ago, fresh clean install. When I had "Kodi 17 Krypton" everything was fine, but now with Kodi 18.1 I'm experiencing this issue of audio delay when  "Adjust display refresh rate" is enabled.
Is something was broken in Kodi Leia?
See: https://github.com/LibreELEC/LibreELEC.t...ngs.xml#L8 -> and overwrite it. This was "roled with a dice" many years ago, might not be true for your system.
ok, got it
I made a backup of my old Kodi/LibreELEC so I found my old advancedsettings.xml vs new one , now it make sense.
thanks "fritsch"
