(2019-06-07, 23:09)bennyhanna Wrote: [ -> ]The Grinch (2018) These are real character arts from Universal Pictures.
Very good images and very good quality!
The invisible parts of the edge should be cut short. (especially below)
But these pictures fit well as they are.
(2019-06-08, 21:59)bennyhanna Wrote: [ -> ]The Secret Life of Pets 2 (2019)
I also Have several more of these if wanted.
Sure! If you were would like to post them. I will also add them to the database.
(2019-06-09, 08:45)rschiks Wrote: [ -> ]Sure! If you were would like to post them. I will also add them to the database.
OK, I just have to trim them down...
I have more from The Grinch as well.
(2019-06-09, 11:32)bennyhanna Wrote: [ -> ]I have more
I monitor almost every reputable source on web, i would be very curious where your sources come from (pm)
Is there gonna be a tutorial on how to do the process of adding the character art?Tia
Great thanks @
bennyhanna for your lots of high quality images.
Your images are real renderings and not only just .png cutouts - much appreciated!
Hope there will be mure stuff in the future
Actually, I do not post arts where the theme is the only one used for Cleararts, without any alternative - as in this case.
Because when using clearart and characterart in the skin at the same time it just looks double. (and that looks like sh"")
Here I make an exception as it is the highest quality AAA rendering that I have come across lately,
and maybe not everyone use clearart in skin.
___
X-Men: Dark Phoenix (2019)
This motive can be also used for the second movie cause in both movies Paddington looks the same and has also the equal same clothes (poor guy),
but i'm pretty sure the motive belongs to the first movie:
___
Paddington (2014)
There exist also another high quality rendering but it's the only used for clearart.
This, however, is still "unused":
___
Spring Breakers (2012)
Also the Chipmunks looking in every movie the same and can be used everywhere.
I'm sure it belongs to the first movie. In this image i made a small exception and doesn't cut the edges tight,
i left some space left and right that the image will look a bit smaller than the others in the kodi views
... cause the Chipmunks are small guys. (Feel free cut afterwards)
___
Alvin and the Chipmunks (2007)
