Full Version: kodi 18 and tajo
hi.
ijust installed latest stable kodi 18 today
i also use emby for the library. anyway if i put a widget with tv shows and movies . that doesnt work.
when i start an episode from the widget of also with a movie from a widget it looks like it is starting but after after 1 or 2 seconds it just stays om the home screen.
so from a widget movies and episodes are just not starting.
tried different widgets recently added episode from kodi even from an addon emby also same effect . what is wrong here ??
(2019-03-27, 19:00)style2k Wrote: [ -> ][...] from an addon emby also same effect . what is wrong here ??
Emby? It works faultlessly with my local files...
(2019-03-28, 00:11)manfeed Wrote: [ -> ]
on 17.6 it worked with no problems at all. not with this skin but with normal aeon skin
Since I don't use them much, I didn't change them, widgets are almost the same like in Aeon Nox...
yep widgets are the same but in nox i could play movies and series now i cant not from a widget its wierd
i like the skin but i need it to work.
also widget sometimes just not loading . see the widget box but its empty with just the search thingy
and when editing the menus the option manage submenu is not working either
(2019-03-28, 10:12)style2k Wrote: [ -> ]also widget sometimes just not loading . see the widget box but its empty with just the search thingy
Hey,
Did you get a solution to empty widgets? I am experiencing the same thing. (Android Box, Android 8.1 version)
