Full Version: Subtitles not displaying in MKV
I'm playing an MKV file but not getting subtitles....playing back on a firetv stick.  Is this an issue?
Internal or external subs? SRT, SSA, some other type?
(2019-03-30, 23:29)Klojum Wrote: [ -> ]Internal or external subs? SRT, SSA, some other type?
Sorry my mistake. They are internal to the mkv file. Playing the video in vlc shows them.
(2019-03-31, 00:31)kruuth Wrote: [ -> ]Playing the video in vlc shows them.
I can name some other media players as well, that is not the point.
So what type of subtitles are they? Our crystal ball is out of service during weekends.
An Exiftool report or a MediaInfo summary of your video file would also help more.
(2019-03-31, 06:00)Klojum Wrote: [ -> ]
Here's what came out of MediaInfo:
xml:
<?xml version="1.0" encoding="UTF-8"?>
<MediaInfo
    xmlns="https://mediaarea.net/mediainfo"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsiConfusedchemaLocation="https://mediaarea.net/mediainfo https://mediaarea.net/mediainfo/mediainfo_2_0.xsd"
    version="2.0">
<creatingLibrary version="18.12" url="https://mediaarea.net/MediaInfo">MediaInfoLib</creatingLibrary>
<media ref="D:\Video\Anime\OVA\Girls Und Panzer\Girls Und Panzer - 02 - Tanks, We Ride Them!.720p.m4v">
<track type="General">
<VideoCount>1</VideoCount>
<AudioCount>1</AudioCount>
<FileExtension>m4v</FileExtension>
<Format>MPEG-4</Format>
<Format_Profile>Base Media</Format_Profile>
<CodecID>mp42</CodecID>
<CodecID_Compatible>isom/iso2/avc1/mp41</CodecID_Compatible>
<FileSize>114282104</FileSize>
<Duration>1452.118</Duration>
<OverallBitRate_Mode>VBR</OverallBitRate_Mode>
<OverallBitRate>629602</OverallBitRate>
<FrameRate>23.976</FrameRate>
<FrameCount>34812</FrameCount>
<StreamSize>1059528</StreamSize>
<HeaderSize>40</HeaderSize>
<DataSize>113222584</DataSize>
<FooterSize>1059480</FooterSize>
<IsStreamable>No</IsStreamable>
<File_Created_Date>UTC 2019-03-14 02:44:00.176</File_Created_Date>
<File_Created_Date_Local>2019-03-13 22:44:00.176</File_Created_Date_Local>
<File_Modified_Date>UTC 2019-03-18 04:58:24.991</File_Modified_Date>
<File_Modified_Date_Local>2019-03-18 00:58:24.991</File_Modified_Date_Local>
<Encoded_Application>HandBrake 0.10.1 2015030800</Encoded_Application>
</track>
<track type="Video">
<StreamOrder>0</StreamOrder>
<ID>1</ID>
<Format>AVC</Format>
<Format_Profile>High</Format_Profile>
<Format_Level>5</Format_Level>
<Format_Settings_CABAC>Yes</Format_Settings_CABAC>
<Format_Settings_RefFrames>16</Format_Settings_RefFrames>
<CodecID>avc1</CodecID>
<Duration>1451.951</Duration>
<BitRate>591831</BitRate>
<Width>1280</Width>
<Height>720</Height>
<Sampled_Width>1280</Sampled_Width>
<Sampled_Height>720</Sampled_Height>
<PixelAspectRatio>1.000</PixelAspectRatio>
<DisplayAspectRatio>1.778</DisplayAspectRatio>
<Rotation>0.000</Rotation>
<FrameRate_Mode>VFR</FrameRate_Mode>
<FrameRate_Minimum>23.810</FrameRate_Minimum>
<FrameRate_Maximum>24.272</FrameRate_Maximum>
<ColorSpace>YUV</ColorSpace>
<ChromaSubsampling>4:2:0</ChromaSubsampling>
<BitDepth>8</BitDepth>
<ScanType>Progressive</ScanType>
<StreamSize>107413776</StreamSize>
<Encoded_Library>x264 - core 142 r2479 dd79a61</Encoded_Library>
<Encoded_Library_Name>x264</Encoded_Library_Name>
<Encoded_Library_Version>core 142 r2479 dd79a61</Encoded_Library_Version>
<Encoded_Library_Settings>cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60</Encoded_Library_Settings>
<colour_description_present>Yes</colour_description_present>
<colour_description_present_Source>Stream</colour_description_present_Source>
<colour_range>Limited</colour_range>
<colour_range_Source>Stream</colour_range_Source>
<colour_primaries>BT.709</colour_primaries>
<colour_primaries_Source>Stream</colour_primaries_Source>
<transfer_characteristics>BT.709</transfer_characteristics>
<transfer_characteristics_Source>Stream</transfer_characteristics_Source>
<matrix_coefficients>BT.709</matrix_coefficients>
<matrix_coefficients_Source>Stream</matrix_coefficients_Source>
<extra>
<Codec_configuration_box>avcC</Codec_configuration_box>
</extra>
</track>
<track type="Audio">
<StreamOrder>1</StreamOrder>
<ID>2</ID>
<Format>AAC</Format>
<Format_Commercial_IfAny>HE-AAC</Format_Commercial_IfAny>
<Format_Settings_SBR>Yes (NBC)</Format_Settings_SBR>
<Format_AdditionalFeatures>LC SBR</Format_AdditionalFeatures>
<CodecID>mp4a-40-5</CodecID>
<BitRate_Mode>VBR</BitRate_Mode>
<BitRate>32002</BitRate>
<Channels>2</Channels>
<ChannelPositions>Front: L R</ChannelPositions>
<ChannelLayout>L R</ChannelLayout>
<SamplesPerFrame>2048</SamplesPerFrame>
<SamplingRate>48000</SamplingRate>
<SamplingCount>69701664</SamplingCount>
<FrameRate>23.438</FrameRate>
<FrameCount>34034</FrameCount>
<Compression_Mode>Lossy</Compression_Mode>
<StreamSize>5808800</StreamSize>
<StreamSize_Proportion>0.05083</StreamSize_Proportion>
<Title>Stereo / Stereo</Title>
<Language>en</Language>
<Default>Yes</Default>
<AlternateGroup>1</AlternateGroup>
</track>
</media>
</MediaInfo>
Want to point out that Kodi sees the subs it just won't play them.
