2008-06-24, 04:23
2008-06-24, 07:45
It's meant to be working in library mode.
agathorn Wrote:I've now added support for local fanart IMAGES and will get it into SVN as soon as I can.
You can place a fanart.jpg, or fanart.png file in the shows main folder, IE:
And XBMC will use that as the fanart image. This method does NOT provide color information.
If a show already has fanart assigned to it, the fanart.jpg method wont' work, because it won't override what you already had set (for safety :p) so in order to change it simlply go to the Choose Fanart window, select BROWSE, and then select the local image you want to use as fanart.
agathorn Wrote:Ok this is now in SVN, thanks jmarshall!
2008-06-24, 09:22
Hitcher Wrote:It's meant to be working in library mode.
That isn't movie fanart, that's local TV show fanart
2008-06-24, 15:03
Sorry, it was early.
2008-06-24, 15:18
I think movie fanart needs to be named:
<moviename>-fanart.jpg or .png and be in the same directory as the movie file.
i.e.
Magnum Force (1973).mkv
i.e.
2008-06-24, 15:21
Yup... here it is:
http://dn-0.com/xbmc-trac/changeset/13661
Its local files only at the moment so no tvdb style autopull...
2008-06-24, 16:01
Weavus Wrote:I think movie fanart needs to be named:
i.e.
This is what I've tried without success. Am I missing something?
2008-06-24, 16:44
Anything in your logfiles?
2008-06-24, 17:26
the image will then be available as
listitem.property(fanart_image)
fanart.image is the CONTAINER fan art, not the select item's fanart
2008-06-24, 18:29
Ahh, much obliged. I'll give it a try later.
2008-06-24, 20:43
Would I be right in thinking that, because the listitem fanart ceases to exist the second you move to an adjacent item, it's impossible to fade these images out?
2008-06-24, 22:04
That sounds right, yes. Just the same as any other image that depends on the listitem.
2008-06-24, 22:10
Is there any way of combining the fanart_image object with a multiimage control to enable crossfading? Or am I being completely stupid now?
2008-06-24, 23:15
No, there is not.
