Hey, compiled and built for arm.
Then tried to reconfigure for aarch64, did 5-8 steps from readme. and end result is again build for arm (armeabi-v7a)...
What am I doing wrong?
Done on Ubuntu 18.04.2 LTS on a virtual box.
PS - had to install/update clang and downgrade java to ver 8 (due to packaged gradle version)
you have to clean the kodi build dir before you change the target, or it will use cached data
(2019-04-01, 20:24)wsnipex Wrote: [ -> ]you have to clean the kodi build dir before you change the target, or it will use cached data
thanks that worked!
btw, configured --disable-debug and everything in log was prepared for 'release' but when building kodi still got 'debug' name in file - is it just naming leftover?
(2019-04-02, 13:46)cartman.dos Wrote: [ -> ] (2019-04-01, 20:24)wsnipex Wrote: [ -> ]you have to clean the kodi build dir before you change the target, or it will use cached data
thanks that worked!
Hi, did you get any update on the apk file name having 'debug'?
(2019-05-02, 23:29)atrdurai Wrote: [ -> ] (2019-04-02, 13:46)cartman.dos Wrote: [ -> ] (2019-04-01, 20:24)wsnipex Wrote: [ -> ]you have to clean the kodi build dir before you change the target, or it will use cached data
thanks that worked!
Nah, but pretty sure it's not a debug ver, it's recognized as 'dirty' (guessing due to self-signed) and it functions like any other, plus the log file is not in debug mode. But IDK how a 'debug' ver would behave otherwise... so if someone can confirm that...
