2019-04-01, 21:23
Hi
I try to wipe/clear sets like "art","uniqueid" or "ratings" via JSON, e.g. ratings for an episode. If I sync a bunch of ratings like
I have not found a way to delete existing rating entries. For uniqueid it works if I send a "null" value like
IMO existing entires should be removed automatically with each new "SetXYDetails" JSON command if a set has an entry. Also it should be possible to clean a whole set without reading existing entries.
new ratings will be added and already existing will be overwritten, but all the others who not are in the "new" list will not be removed.json:{"episodeid":37,"ratings":{"imdb":{"rating":8.5,"votes":44444},"themoviedb":{"rating":7.7,"votes":20}}}
but for that first I've to get a list of all existing entries via "GetEpisodeDetails", then I've to add the not in new list existing entries with a "null" value only to clean no longer valid IDs from that list. Same for "art" entries.json:{"episodeid":37,"uniqueid":{"imdb":null,"themoviedb":"45578"}}
