Hey,...
I desire to update my video python 2 addon to python 3...
my python 2 video addon used CommonFunctions from script.common.plugin.cache
but
it seems not working with python 3 version...at this moment
so i have tried with BeautifulSoup but no working too.....
so my question is this one,....
what are the tools that i can use to make a functionnal video scrap addon with kodi python 3 version,.....?
EDIT:: SOrry.. i havent seen that post --->>> ::
https://forum.kodi.tv/showthread.php?tid=325637
(2019-04-03, 17:54)ronie Wrote: [ -> ]a python 3 compatible version of Beautifulsoup is available in our repo for v19:
http://mirrors.kodi.tv/addons/migration/...ifulsoup4/
Hey ronie,...
Thx for your intervention,...
but i still have issues with ""import from zip"" the file : script.module.beautifulsoup4-4.6.0.0.zip
after manual install of the beautifulsoup addon,
i have got this error :
ImportError: No module named html.entities
after manual add of html lib from python 3 install folder,..
i have this issue
Error Type: <type 'exceptions.ValueError'>
Error Contents: chr() arg not in range(256)
""and it s apparenetly related to the fact that Python 2 chr give a one character string in the ASCII range. This is an 8-bit string, so the maximum parameter value for
chr is 255.... In Python 3 you'll get a unicode character and unicode code points can go up to much higher values.""
have you an idea..?
hard to tell without seeing the code and a full
Debug Log.
looking at the error alone, i'd say your not using a py3 version of kodi... but that's just a guess.
(2019-04-03, 22:45)ronie Wrote: [ -> ]....
do you consider leia 18.1 version as a python3 kodi version..?
(2019-04-03, 23:35)ronie Wrote: [ -> ]nope, you need to install the 'feature_python3' test build of kodi.
the can be found here: http://mirrors.kodi.tv/test-builds/
ohh thx for the info .....and sorry for misunderstanding..
i go catch this version 'feature_python3' test build of kodi...now..
thx for the enlightenment,...
ronie
I am trying to convert a couple of addons to py3 so that I may submit to the official repo.
I tried installing the script.common.plugin.cache-2.5.10.zip from
http://mirrors.kodi.tv/addons/migration/script.common.plugin.cache/
It immediately gives an error on install
from the log file
Error Type: <class 'AttributeError'>
Error Contents: 'str' object has no attribute 'decode'
File "/home/gujal/.kodi/addons/script.common.plugin.cache/default.py", line 40, in <module>
run()
File "/home/gujal/.kodi/addons/script.common.plugin.cache/default.py", line 30, in run
sys.path = [settings.getAddonInfo('path').decode('utf-8') + "/lib"] + sys.path
AttributeError: 'str' object has no attribute 'decode'
From the error, it looks like the module is still using python2 calls and is not updated for python3
Here is the full debug log
https://paste.kodi.tv/ilopinunuj.kodi
Please advise
correct, script.common.plugin.cache has not been updated to python3.
ronie
i come back to you because i still have issue with the script.module.beautifulsoup4-4.6.0.0.zip and the KodiSetup-20190305-66746cbe-feature_python3-x64.exe
i cant install from zip
the original addon.xml of beautifulsoup4-4.6.0.0 has xbmc.python" version="2.25.0"
i have modified this to xbmc.python" version="2.26.0"
but with no succes
and when i add manually script.module.beautifulsoup4-4.6.0.0
i have an import error on from bs4 import BeautifulSoup
SOLUTION :
i have put some lib from python 3 install folder in my addon folder to do the trick
