Just wondering if the is documentation on how the Python metadata scrapers work. Mostly after I scrape and build the item with Kodi supported metadata is there a pythonic way I can insert it into Kodi library?
We need more docs on what is needed to make this work. I got it to scan and attempt to load the directory, but...nothing added.
You can look at the code on
GitHub and reuse what you please. I don't mind if you use any of the code there, including the helpers I've written. The kodi_models file is quite useful.
Issue 306 of Nakamori has updates on the headaches and bugs we've encountered.
EDIT: BTW it's called a scraper, not a scrapper. I don't know why, but so many people mix that up. A scrapper would turn garbage into something more useful. A scraper takes data from somewhere and uses it in a different format.
I got it working! Check the GitHub link. I'll clean it up a bit and push.
EDIT: Specifically, look at the functions in plugin.video.nakamori/nakamoriplugin.py that start with `scrape`, as well as script.module.nakamori-lib/lib/shoko_models/v2.py for the methods get_listitem() and get_infolabels(). Series and Episode are the relevant classes for the Metadata agent.
(2019-04-07, 01:54)ronie Wrote: [ -> ]
the answer hasn't changed since the last time you asked... no, scrapers can not add items to the library themselves.
Haha Thanks I will look at the example you provided thanks
Ronie, not sure if you missed it, but the answer you gave is now incorrect.
https://github.com/xbmc/xbmc/pull/13566
Starting there, addons can add items to the library. 18.2 will have support for it.
(2019-04-07, 03:00)da3dsoul Wrote: [ -> ]Ronie, not sure if you missed it, but the answer you gave is now incorrect.
'addons' is a bit of a generic term ;-)
my comments are related to metadata scraper addons, the ones that use the "xbmc.metadata.scraper.*" extension point.
That is fair. We now have Metadata Plugins, which explicitly add new items to the library from a plugin path, as well as Metadata Scraper Addons, which can't add items, but instead fetch info for existing items.
