2019-04-07, 12:38
Clean install of kodi 18.1 on clean shield tv with latest android tv version. Shield tv has also been factory reseted. When I try access from kodi repositories that using https links i got error in log file:
Any plugin that using ssl connections are not working to. I got this error in log:
I tried older kodi verrsion 17. Many times factory reset on shield and nothing helps. I got samsung s9 in same network and everything is ok with 18.1 but shield has problems. Any help?
xml:
ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
xml:
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'requests.exceptions.SSLError'>
Error Contents: HTTPSConnectionPool(host='****', port=443): Max retries exceeded with url: /url (Caused by SSLError(SSLError(1, u'[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:726)'),))
