Full Version: How can TMM automatically rename the file names of movies and series?
How can TMM automatically rename the file names of movies and series (when updating the data sources or before)?
that is not the workflow of tmm
a) update data sources (aka import your movies/tv shows into tmm)
b) scrape them (download meta data from the net)
c) rename them according to the meta data
rename before b) or even before a) simply makes no sense
You have to start c) separately? TMM can not do it automatically after b)?
Can TMM rename all of the files (also txt files, pngs, jpgs, idx, etc.) in the folder the movie is and the folder containing the movie?
- there is an option to let tmm rename after scraping
yes, tmm will rename all associated files for your movies (nfo files, artwork files, subtitles) -> .txt will not be renamed
Quote:- there is an option to let tmm rename after scraping
Great, where is it? And this option causes TMM to automatically rename after scraping?
So finally TMM can rename the movie files and the other ones and automatically create the folder for the each movie. So there is no need to rename the files with another program.
posted two links at the other thread - read/watch these and get a feeling what tmm is for Wink
Great, many thanks!
