Full Version: TV Shows sorted by date, how ?
Is there a way to sort TV shows by date, maybe using views ?
thanks in advance.
Regards.
In theory: yes, with a custom list (view) for shure, but I'm not 100% shure if not some function set the sorting back to the list control. Usually the sorting of the SQL query will be ignored and the GUI controls the sorting depending on the column that you've clicked.
(2019-04-11, 00:38)DanCooper Wrote: [ -> ]In theory: yes, with a custom list (view) for shure, but I'm not 100% shure if not some function set the sorting back to the list control. Usually the sorting of the SQL query will be ignored and the GUI controls the sorting depending on the column that you've clicked.
well, in a future version, would it be possible to add a "Date Added" sort button to the TV Shows panel as in the Movie panel ?
Regards.
