Full Version: Supported Video/Audio Values for Codec
Hello,
i am looking for a list of supported string values for Video & Audio Codec
The exampels in the docs works: https://codedocs.xyz/AlwinEsch/kodi/grou...fec9111cdc
However i dont know what value to use for "dolby digital" for example.
Rgds
PX80
edit: so i figured the following (trial and error )
Video Codecs
mp4
h264
h265
mkv
hevc
Audio Codec
aac
ac3
dts
(2019-04-11, 13:02)Klojum Wrote: [ -> ]You meant this? https://kodi.wiki/view/Features_and_supported_formats
Thanks. I wonder if the Skin ( Helper) can identify the tags listed in this webpage. But i think i can work with the tags in the list
Thanks. What i am missing on the list is the Audio Format: Dolby Digital and DD+  ( i believe AC3 encodes to DD )
For DD+ i tried
codec:aacplus & codec:aac+
None of them works.
edit: its codec:eac3
there's no 'complete' list of possible audiocodec/videocodec values...
afaik they are provided by ffmpeg and there are a whole lot of them.
the most common ones can usually be found in many skins:
https://github.com/xbmc/xbmc/tree/master...audiocodec
https://github.com/xbmc/xbmc/tree/master...videocodec
