Full Version: Error sorting by year in locatión disk select
When I select a location and I want to sort by year I get an error message from java and I have to close the application.
Thanks in advance.
https://paste.kodi.tv/raw/ixivuyogay
are you able to reproduce that?
I could not reproduce that issue
ava.lang.NullPointerException
    at ca.odell.glazedlists.impl.adt.barcode2.SimpleTree.get(SimpleTree.java:160)
    at ca.odell.glazedlists.SortedList.getSourceIndex(SortedList.java:394)
    at ca.odell.glazedlists.TransformedList.get(TransformedList.java:107)
    at ca.odell.glazedlists.swing.DefaultEventTableModel.getValueAt(DefaultEventTableModel.java:192)
    at javax.swing.JTable.getValueAt(Unknown Source)
    at javax.swing.JTable.prepareRenderer(Unknown Source)
    at org.tinymediamanager.ui.components.table.TmmTable.prepareRenderer(TmmTable.java:243)
    at javax.swing.plaf.basic.BasicTableUI.paintCell(Unknown Source)
    at javax.swing.plaf.basic.BasicTableUI.paintCells(Unknown Source)
    at javax.swing.plaf.basic.BasicTableUI.paint(Unknown Source)
    at javax.swing.plaf.ComponentUI.update(Unknown Source)
    at javax.swing.JComponent.paintComponent(Unknown Source)
    at javax.swing.JComponent.paint(Unknown Source)
    at javax.swing.JComponent.paintChildren(Unknown Source)
    at javax.swing.JViewport.paint(Unknown Source)
    at javax.swing.JSplitPane.paintChildren(Unknown Source)
    at javax.swing.JLayer.paint(Unknown Source)
    at javax.swing.plaf.LayerUI.paint(Unknown Source)
    at org.tinymediamanager.ui.ShadowLayerUI.paint(ShadowLayerUI.java:37)
    at javax.swing.JLayeredPane.paint(Unknown Source)
    at javax.swing.JComponent.paintToOffscreen(Unknown Source)
    at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
    at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
    at javax.swing.RepaintManager.paint(Unknown Source)
    at javax.swing.JComponent._paintImmediately(Unknown Source)
    at javax.swing.JComponent.paintImmediately(Unknown Source)
    at javax.swing.RepaintManager$4.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
    at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
    at javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
    at javax.swing.RepaintManager.access$1200(Unknown Source)
    at javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.access$500(Unknown Source)
    at java.awt.EventQueue$3.run(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.WaitDispatchSupport$2.run(Unknown Source)
    at java.awt.WaitDispatchSupport$4.run(Unknown Source)
    at java.awt.WaitDispatchSupport.enter(Unknown Source)
    at java.awt.Dialog.show(Unknown Source)
    at java.awt.Component.show(Unknown Source)
    at java.awt.Component.setVisible(Unknown Source)
    at java.awt.Window.setVisible(Unknown Source)
    at java.awt.Dialog.setVisible(Unknown Source)
    at org.tinymediamanager.ui.dialogs.TmmDialog.setVisible(TmmDialog.java:239)
    at org.tinymediamanager.ui.dialogs.MessageDialog.showExceptionWindow(MessageDialog.java:124)
    at org.tinymediamanager.Log4jBackstop.uncaughtException(Log4jBackstop.java:43)
    at java.lang.ThreadGroup.uncaughtException(Unknown Source)
    at java.awt.EventDispatchThread.processException(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
still not able to reproduce..
please provide detailed instructions what you are doing
(2019-04-22, 17:07)mlaggner Wrote: [ -> ]still not able to reproduce..
sorting from highest to lowest in the path column after filter duplicated films.
Thanks in advance
should be fixed within the next build
