(2019-08-30, 19:50)Øyvind Wrote: [ -> ]Hi
All versions from #0826 on start again and again up to the safe mode.
https://pastebin.com/Y1zyH1wp
https://pastebin.com/PGjLBLmV
Øyvind
Ping @
phunkyfish - seems to be pvr.iptvsimple related?
text:
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f0a7bb1f15f in void rapidxml::xml_document<char>::parse<0>(char*) () from /usr/lib/kodi/addons/pvr.iptvsimple/pvr.iptvsimple.so.4.4.0
New LibreELEC.tv Matrix build #0830:
Generic
(Supercedes previous build)
SHA256 Checksum:
960f18b51aaabe4745bcb59569b828af38188fa2dceaa968c28b9e47bd331a79
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Fri Aug 30 21:08:30 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190830210750-#0830-gbd4ba9f [Build #0830]
# Kodi version
Kodi (19.0-ALPHA1 Git:e04050a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (bd4ba9f,
changelog) and tip of
XBMC master (e04050a,
- Includes latest kodi-platform master (809c5e9, ahead +2)
- Includes latest libcec master (ba9b538, ahead +1)
- Includes latest libnfs master (ca939ba, ahead +3)
- Includes latest p8-platform master (cee64e9)
- Includes latest addons: inputstream.adaptive (3df8a84, +30), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (16d04ed, +16), pvr.demo (a724cdd, +13), pvr.dvblink (1965165, +16), pvr.dvbviewer (d6f2efb, +12), pvr.filmon (e45af00, +14), pvr.freebox (72cc0db, +9), pvr.hdhomerun (a0eb1ee, +13), pvr.hts (2b51b2e, +13), pvr.iptvsimple (6d525c8, +35), pvr.mediaportal.tvserver (c4cb109, +18), pvr.mythtv (4e6465b, +14), pvr.nextpvr (5122640, +8), pvr.njoy (fe6d356, +8), pvr.octonet (9d98f2b, +8), pvr.pctv (c6b5080, +6), pvr.sledovanitv.cz (865bd6e, +12), pvr.stalker (2c87bf4, +7), pvr.teleboy (0dc9eb1, +5), pvr.vbox (5385416, +9), pvr.vdr.vnsi (f6c7cac, +10), pvr.vuplus (457a28d, +55), pvr.waipu (62bcdf9, +26), pvr.wmc (477fca9, +7), pvr.zattoo (abd06f3, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] compare (perma): kodi19: next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] compare (perma): mesonbuild: update to 0.51.2
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3667 (perma): libbluray: update to 1.1.2
- Include [env] PR:3743 (perma): linux (Mainline/RPi): update to linux-5.2.11
- Include [env] PR:3772 (perma): mesa: update to mesa-19.1.5
- Include [env] PR:3774 (perma): tinyxml2: update to tinyxml2-7.1.0
- Include [env] PR:3778 (perma): samba: update to samba-4.9.12
- Include [env] PR:3779 (perma): squashfs-tools: renamed squashfs / updated to git 6edf624
- Revert [env] PR:3698 ([url=]perma[/url]): kodi: building with ninja makes xbmc/1600 more likely - don't use ninja
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:21 (perma): Update firmware for 5.2.9 (iwlwifi-fw-2019-08-23) (iwlwifi-firmware)
- Include [pkg] PR:132 (perma): background recreated to avoid interlaced images (service.libreelec.settings)
- Include [pkg] PR:275 (perma): Support multiple credits elements, firstAired, year, star rating, episode-num in epg entry, readme update, multiple display-names's and matching channels, plus bugfixes - Matrix (pvr.iptvsimple)
- Include [pkg] PR:15831 (perma): [libUPnP] Remove unused headers from Platinum/Source/Extras
- Include [pkg] PR:16216 (perma): resolution whitelist version 2
- Include [pkg] PR:16494 (perma): cmake: use external process to avoid "file COPY" failures, fixes #16000
Build Highlights:
- New 5.2.11 kernel
Build Details:
- XBMC:
- [addons] use on build in binary addons only `library="dummy.so"` (PR:16531, 1 commit, 4 files changed)
- [Inputstream Addon] Add missing breaks (PR:16545, 1 commit, 1 file changed)
- pvr.filmon:
- [Matrix] build system cleanup / increase version to 3.0.1 (PR:91, 8 commits, 11 files changed)
- pvr.mediaportal.tvserver:
- [Matrix] update CMakeLists.txt to 3.5, change header include and increase version to 4.1.1 (PR:107, 6 commits, 15 files changed)
- Updated: [env] PR:3743 (perma): linux (Mainline/RPi): update to linux-5.2.11
- Updated: [env] PR:3779 (perma): squashfs-tools: renamed squashfs / updated to git 6edf624
- Updated: [pkg] PR:275 (perma): Support multiple credits elements, firstAired, year, star rating, episode-num in epg entry, readme update, multiple display-names's and matching channels, plus bugfixes - Matrix (pvr.iptvsimple)
(2019-08-30, 23:36)phunkyfish Wrote: [ -> ] (2019-08-30, 19:50)Øyvind Wrote: [ -> ]Hi
Øyvind
Can you send me (or PM me) the M3U and epg file you are using? Then I should be able to reproduce and fix the issue.
Problem solved, you tracked me down, it was a broken EPG file.
Thank you
(2019-08-31, 13:40)Øyvind Wrote: [ -> ] (2019-08-30, 23:36)phunkyfish Wrote: [ -> ] (2019-08-30, 19:50)Øyvind Wrote: [ -> ]Hi
Øyvind
Thank you
Please send me the broken EPG file. It’s shouldn’t cause a crash. I can fix it so it won’t do that in future.
Milhouse I warmly welcome. I am writing to you with a question and a request. I'm sitting on version # 0301 and I can't move on because Transmission will no longer work on your builds from THORADIA. Is it possible to have some cooperation with the creator, or just like you used to have your Transmission on openelec and your compilations ?? Best regards and wish you continued fruitful work on your biulds.
(2019-08-31, 13:58)witek666 Wrote: [ -> ]@Milhouse I warmly welcome. I am writing to you with a question and a request. I'm sitting on version # 0301 and I can't move on because Transmission will no longer work on your builds from THORADIA. Is it possible to have some cooperation with the creator, or just like you used to have your Transmission on openelec and your compilations ?? Best regards and wish you continued fruitful work on your biulds.
I believe you will need to use Docker for Transmission, as Transmission is not natively supported by LibreELEC (and I have no intention of providing a Transmission add-on). Please use the LibreELEC forum for feature requests (as mentioned in the first post).
New LibreELEC.tv Matrix build #0831:
Generic
SHA256 Checksum:
77258ca3a14e4a5825ba0014b733548417f1f43082667bf70f660f0fbc6288a0
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Sat Aug 31 21:03:46 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190831210305-#0831-gbd4ba9f [Build #0831]
# Kodi version
Kodi (19.0-ALPHA1 Git:2bfbe71). Platform: Linux x86 64-bit
Based on tip of
XBMC master (2bfbe71,
- Includes latest addons: inputstream.adaptive (3df8a84, +30), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (16d04ed, +16), pvr.demo (a724cdd, +13), pvr.dvblink (1965165, +16), pvr.dvbviewer (d6f2efb, +12), pvr.filmon (e45af00, +14), pvr.freebox (72cc0db, +9), pvr.hdhomerun (a0eb1ee, +13), pvr.hts (2b51b2e, +13), pvr.iptvsimple (6d525c8, +35), pvr.mediaportal.tvserver (c4cb109, +18), pvr.mythtv (502769d, +17), pvr.nextpvr (945ceaf, +15), pvr.njoy (f095423, +16), pvr.octonet (9d98f2b, +8), pvr.pctv (3aea8d9, +14), pvr.sledovanitv.cz (865bd6e, +12), pvr.stalker (2c87bf4, +7), pvr.teleboy (0dc9eb1, +5), pvr.vbox (5385416, +9), pvr.vdr.vnsi (f6c7cac, +10), pvr.vuplus (457a28d, +55), pvr.waipu (62bcdf9, +26), pvr.wmc (477fca9, +7), pvr.zattoo (abd06f3, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
Build Highlights:
- Fix EPG segfault introduced in #0826 (thanks Øyvind)
Build Details:
- XBMC:
- [screensaver.xbmc.builtin.dim] reduce dim minimum threshold (PR:16529, 1 commit, 2 files changed)
- pvr.mythtv:
- sync with master (6.1.2) (PR:129, 3 commits, 10 files changed)
- pvr.nextpvr:
- [Matrix] build system cleanup / increase version to 4.1.1 (PR:97, 7 commits, 14 files changed)
- pvr.njoy:
- [Matrix] build system cleanup / increase version to 4.0.1 (PR:50, 8 commits, 9 files changed)
- pvr.pctv:
- [Matrix] update CMakeLists.txt to 3.5, change header include and increase version to 3.0.1 (PR:66, 8 commits, 10 files changed)
New LibreELEC.tv Matrix build #0901:
Generic
SHA256 Checksum:
f81dd2e4dac1be7de46c843e02ffef2e3e2ed0062680456e87fa88fbfc7d91f3
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Sun Sep 1 23:48:51 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190901234810-#0901-g05d8b30 [Build #0901]
# Kodi version
Kodi (19.0-ALPHA1 Git:7ad4acd). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (05d8b30,
XBMC master (7ad4acd,
- Includes latest addons: inputstream.adaptive (0a4350b, +16), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (16d04ed, +16), pvr.demo (a724cdd, +13), pvr.dvblink (1965165, +16), pvr.dvbviewer (d6f2efb, +12), pvr.filmon (e45af00, +14), pvr.freebox (72cc0db, +9), pvr.hdhomerun (a0eb1ee, +13), pvr.hts (2b51b2e, +13), pvr.iptvsimple (6d525c8, +35), pvr.mediaportal.tvserver (c4cb109, +18), pvr.mythtv (6940ca2, +19), pvr.nextpvr (945ceaf, +15), pvr.njoy (f095423, +16), pvr.octonet (9d98f2b, +8), pvr.pctv (3aea8d9, +14), pvr.sledovanitv.cz (865bd6e, +12), pvr.stalker (2c87bf4, +7), pvr.teleboy (0dc9eb1, +5), pvr.vbox (5385416, +9), pvr.vdr.vnsi (f6c7cac, +10), pvr.vuplus (457a28d, +55), pvr.waipu (f949bb4, +27), pvr.wmc (477fca9, +7), pvr.zattoo (abd06f3, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
Build Highlights:
- inputstream.adaptive: switch to Matrix branch
- [PVR] Fix deadlock on PVR shutdown
Build Details:
- LibreELEC.tv:
- mame2015: improve build (PR:3780, 2 commits, 2 files changed)
- [le10] ffmpeg: update to 4.0.4-Leia-18.4 (PR:3784, 1 commit, 1 file changed)
- XBMC:
- [PVR] Fix deadlock on PVR shutdown. (PR:16550, 1 commit, 1 file changed)
- [listproviders] Update addons list on repository updated (PR:16551, 1 commit, 2 files changed)
- [Android] activate keyframe search (PR:15948, 1 commit, 1 file changed)
- [cmake] check present "CPU" variable on PrepareEnv, if empty use CMAKE_SYSTEM_PROCESSOR (PR:16547, 1 commit, 1 file changed)
- update CMakeLists.txt to 3.5 (PR:307, 1 commit, 7 files changed)
- Adapted .travis.yml (690f6a6)
- Adapt appveyor.yml (1139876)
- Simplify decision tree (d029148)
- fix return code of ParseFrameForSPS (ec13716)
- Fix issue where 1080p means 720p (1f2de72)
- [HLS] don't swap segments if download temporary fails (f6ab34b)
- [HLS] support non-multi-bitrate playlists (30e6392)
- [Cleanup] fix rep_esentation typo (6f35eb8)
- [HLS] use effective filename for non-master playlists if available (283890b)
- fix wrong vp9 comparision (c015cb1)
- Version bump 2.3.18 (a92457d)
- [MPD] Fix FixateInitialization (f91e6f4)
- cdmadapter minor changes (28d86a1)
- Compile fix (d98fbc9)
- Merge branch 'master' into Leia (06d0000)
- Fix compiler warning (3962081)
- version bump 2.3.19 (cfae730)
- Merge branch master into Leia (18beb22)
- Merge branch 'master' into Leia (4b275ed)
- Merge branch 'master' into Leia (389eba8)
- Merge branch 'master' into Matrix (7074cc8)
- Final version bump -> 2.4.0 (0a4350b)
- pvr.mythtv:
- Remove p8-platform dependency, it is no longer used. (PR:130, 1 commit, 2 files changed)
- sync with master (6.1.3) (PR:132, 3 commits, 4 files changed)
- pvr.waipu:
- README: Add kodi jenkins badge (PR:26, 1 commit, 1 file changed)
- Updated: [env] compare (perma): kodi19: next
New LibreELEC.tv Matrix build #0902:
Generic
SHA256 Checksum:
1ba250c08a787dd0a20f83b638b2807f5e5d7acbf238885d9a1777585ffc16bc
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Mon Sep 2 21:03:43 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190902210302-#0902-g223b7b0 [Build #0902]
# Kodi version
Kodi (19.0-ALPHA1 Git:7405d26). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (223b7b0,
XBMC master (7405d26,
- Includes latest addons: inputstream.adaptive (89971d8, +18), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (16d04ed, +16), pvr.demo (a724cdd, +13), pvr.dvblink (1965165, +16), pvr.dvbviewer (d6f2efb, +12), pvr.filmon (e45af00, +14), pvr.freebox (72cc0db, +9), pvr.hdhomerun (a0eb1ee, +13), pvr.hts (2b51b2e, +13), pvr.iptvsimple (6d525c8, +35), pvr.mediaportal.tvserver (c4cb109, +18), pvr.mythtv (6940ca2, +19), pvr.nextpvr (945ceaf, +15), pvr.njoy (f095423, +16), pvr.octonet (9d98f2b, +8), pvr.pctv (3aea8d9, +14), pvr.sledovanitv.cz (865bd6e, +12), pvr.stalker (2c87bf4, +7), pvr.teleboy (0dc9eb1, +5), pvr.vbox (5385416, +9), pvr.vdr.vnsi (f6c7cac, +10), pvr.vuplus (457a28d, +55), pvr.waipu (c183855, +28), pvr.wmc (477fca9, +7), pvr.zattoo (abd06f3, +5), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- mesa: update to mesa-19.1.5 (PR:3772, 1 commit, 1 file changed)
- XBMC:
- [depends] bump flatbuffers to 1.11.0 (PR:16527, 1 commit, 4 files changed)
- pvr.waipu:
- Fix: Timers are not displayed (PR:27, 1 commit, 1 file changed)
Weekly Linux 5.3-rc7 build #0902x:
Generic
New LibreELEC.tv Matrix build #0903:
Generic
SHA256 Checksum:
ed0e82b4674ef960bce095d43b82ab58d963d1a7e2544f00ee0ba73e6a0f1406
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Tue Sep 3 23:26:44 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190903232603-#0903-g128937b [Build #0903]
# Kodi version
Kodi (19.0-ALPHA1 Git:cdcabff). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (128937b,
XBMC master (cdcabff,
- Includes latest libnfs master (4de9fb8, ahead +4)
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (f31aa1a, +17), pvr.dvbviewer (023bd0c, +13), pvr.filmon (7f62242, +15), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (526ab42, +36), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +20), pvr.nextpvr (0131278, +16), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (4bdf7f3, +8), pvr.teleboy (ace6ad6, +6), pvr.vbox (c665693, +10), pvr.vdr.vnsi (612c1f9, +11), pvr.vuplus (bead678, +56), pvr.waipu (ab6ec57, +31), pvr.wmc (cfab2b0, +8), pvr.zattoo (ec85eda, +6), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] compare (perma): glvnd
- Include [env] PR:3782 (perma): libvdpau: updated to v1.3
- Include [env] PR:3791 (perma): samba: update to samba-4.9.13
- Include [env] PR:3793 (perma): RPi btuart: Sync with upstream 0.1.11
Build Highlights:
- samba: update to samba-4.9.13
- graphic: use GLVND to dispatch graphic API calls
- PVR/Inputstream.Adaptive version bumps
- [pvr] ability to sort channels and epg by the backend order of channels
Build Details:
- LibreELEC.tv:
- samba: update to samba-4.9.12 (PR:3778, 1 commit, 1 file changed)
- XBMC:
- [modernize] readability-redundant-control-flow (PR:16563, 1 commit, 24 files changed)
- [pvr] ability to sort channels and epg by the backend order of channels (PR:16558, 1 commit, 22 files changed)
- [Android] Update build (4.1 -> 5.4.1) and SDK (26 -> 28) versions (PR:16559, 1 commit, 5 files changed)
- libnfs:
- add LIBNFS_FEATURE_UMOUNT macro (PR:296, 1 commit, 1 file changed)
- pvr.argustv:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:93, 1 commit, 2 files changed)
- pvr.demo:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:72, 1 commit, 1 file changed)
- pvr.dvblink:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:125, 1 commit, 2 files changed)
- pvr.dvbviewer:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:82, 1 commit, 2 files changed)
- pvr.filmon:
- pvr.freebox:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:22, 1 commit, 1 file changed)
- pvr.hdhomerun:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:87, 1 commit, 2 files changed)
- pvr.hts:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:428, 1 commit, 2 files changed)
- pvr.iptvsimple:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:276, 1 commit, 2 files changed)
- Recompile for 6.1.0 PVR Addon API compatibility (PR:109, 1 commit, 2 files changed)
- pvr.mythtv:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:133, 1 commit, 2 files changed)
- pvr.nextpvr:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:100, 1 commit, 2 files changed)
- pvr.njoy:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:52, 1 commit, 2 files changed)
- pvr.octonet:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:35, 1 commit, 1 file changed)
- pvr.pctv:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:68, 1 commit, 2 files changed)
- pvr.sledovanitv.cz:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:38, 1 commit, 1 file changed)
- pvr.stalker:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:129, 1 commit, 2 files changed)
- pvr.teleboy:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:24, 1 commit, 2 files changed)
- pvr.vbox:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:223, 1 commit, 2 files changed)
- pvr.vdr.vnsi:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:122, 1 commit, 2 files changed)
- pvr.vuplus:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:247, 1 commit, 2 files changed)
- pvr.waipu:
- Add settings menu option to (re-)install widevine (PR:29, 2 commits, 4 files changed)
- Recompile for 6.1.0 PVR Addon API compatibility (PR:31, 1 commit, 1 file changed)
- pvr.wmc:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:73, 1 commit, 2 files changed)
- pvr.zattoo:
- Recompile for 6.1.0 PVR Addon API compatibility (PR:57, 1 commit, 2 files changed)
- Added: [env] compare (perma): graphic: use GLVND to dispatch graphic API calls
- Added: [env] PR:3782 (perma): libvdpau: updated to v1.3
- Added: [env] PR:3791 (perma): samba: update to samba-4.9.13
- Added: [env] PR:3793 (perma): RPi btuart: Sync with upstream 0.1.11
- Added: [pkg] PR:275 (perma): Support multiple credits elements, firstAired, year, star rating, episode-num in epg entry, readme update, multiple display-names's and matching channels, plus bugfixes - Matrix (pvr.iptvsimple)
New LibreELEC.tv Matrix build #0904:
Generic
SHA256 Checksum:
5eac877cf92fc46e1b0780be21cdf6d32c49f540517864c0e573b4ca41363d94
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Wed Sep 4 21:12:46 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190904210926-#0904-g45fa149 [Build #0904]
# Kodi version
Kodi (19.0-ALPHA1 Git:8b45479). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (45fa149,
XBMC master (8b45479,
- Includes latest addons: inputstream.adaptive (54ef24e, +19), inputstream.rtmp (ce68b77, +1), peripheral.joystick (4223dad, +18), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2, +17), pvr.demo (59e3374, +14), pvr.dvblink (f31aa1a, +17), pvr.dvbviewer (023bd0c, +13), pvr.filmon (7f62242, +15), pvr.freebox (7fb6d44, +10), pvr.hdhomerun (4465445, +14), pvr.hts (e96fdd1, +14), pvr.iptvsimple (938f202, +57), pvr.mediaportal.tvserver (84c35b3, +19), pvr.mythtv (dd512aa, +20), pvr.nextpvr (0131278, +16), pvr.njoy (fdffa7d, +17), pvr.octonet (14d3e9d, +9), pvr.pctv (31d8278, +15), pvr.sledovanitv.cz (0384d67, +13), pvr.stalker (4bdf7f3, +8), pvr.teleboy (ace6ad6, +6), pvr.vbox (c665693, +10), pvr.vdr.vnsi (612c1f9, +11), pvr.vuplus (bead678, +56), pvr.waipu (ab6ec57, +31), pvr.wmc (cfab2b0, +8), pvr.zattoo (ec85eda, +6), vfs.libarchive (bb9bda3, +12), vfs.rar (b688a56, +9), vfs.sftp (1c95802, +19)
- Include [env] PR:3790 (perma): graphic: use GLVND to dispatch graphic API calls
- Include [pkg] 275772b2: cmake: use external process to avoid "file COPY" failures, fixes #16000 (kodi)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- samba: update to samba-4.9.13 (PR:3791, 1 commit, 1 file changed)
- XBMC:
- Pvr coverity (PR:16568, 2 commits, 2 files changed)
- pvr.iptvsimple:
- Support multiple credits elements, firstAired, year, star rating, episode-num in epg entry, readme update, multiple display-names's and matching channels, plus bugfixes - Matrix (PR:275, 21 commits, 31 files changed)
- Updated: [env] PR:3790 (perma): graphic: use GLVND to dispatch graphic API calls
- Updated: [pkg] 275772b2: cmake: use external process to avoid "file COPY" failures, fixes #16000 (kodi)
New LibreELEC.tv Matrix build #0905:
Generic
SHA256 Checksum:
e80624ee4ac45757d315a28080dca2673dbc68346933c9187bea580b12b236ce
(Generic)
text:
# uname -a
Linux NUC 5.2.11 #1 SMP Thu Sep 5 21:10:32 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190905210728-#0905-g15b91a1 [Build #0905]
# Kodi version
Kodi (19.0-ALPHA1 Git:df4baf4). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (15b91a1,
XBMC master (df4baf4,
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- squashfs-tools: renamed squashfs / updated to release 4.4 (PR:3779, 2 commits, 4 files changed)
- XBMC:
- [modernize] readability-redundant-smartptr-get (PR:16573, 1 commit, 35 files changed)
