Semi OT
I used getedid create command
Edid.cpio created successfully and I see in log system that edid is loaded
BUT if I don't switch on AVR before Kodi starts I don't have DTS HD and DOLBY HD option in system/audio
I got only DOLBY ac3 and dts
If I switch on AVR before Kodi i can see DTS and DOLBY HD option
And also in playback same problem
I'm pretty sure that with Kodi 18 there wasn't this problem
But i used getedid script only with kodi 19, with Kodi 18 I used Kodi wiki guide
https://wiki.libreelec.tv/custom_edid#tab__intel
Roby77 try running:
cd /tmp; rm -fr /tmp/lib; cpio -F /flash/edid.cpio -i; cat /tmp/lib/firmware/edid/edid.bin | edid-decode | pastebinit
and paste the link to the decoded edid.
Also, run
pastekodi
and paste the link, thanks.
(2020-01-07, 00:42)Roby77 Wrote: [ -> ]2)LibreELEC:/tmp # pastekodi
/usr/bin/pastekodi: line 94: cmp: not found
Cr@p.
Will need to fix that ASAP. Thanks for mentioning it.
cmp
comes from
system-tools
and I imagine everyone testing has that installed.
I've asked other team members if they have any ideas about the edid issue.
(2020-01-07, 01:19)Roby77 Wrote: [ -> ]Sorry @Milhouse sorry to bother you also regarding this problem https://forum.kodi.tv/showthread.php?tid=350348 how can i use a modded edid.bin to remove 10bit and 12bit color mode ? (see https://forum.kodi.tv/showthread.php?tid...pid2910422)
edid isn't really my area, so can't really help on how to modify it - hopefully someone else will have ideas.
New LibreELEC.tv Matrix build #0106:
Generic
(Supercedes previous build)
SHA256 Checksum:
f9cb137597c7ee1f56fed2998dd2500b6aa66e484e7b5e916451a33ab2a9528c
(Generic)
text:
# uname -a
Linux NUC 5.4.8 #1 SMP Mon Jan 6 22:36:45 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200106223302-#0106-geda06b1 [Build #0106]
# Kodi version
Kodi (19.0-ALPHA1 Git:e9806a3). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (eda06b1,
changelog) and tip of
XBMC master (e9806a3,
- Includes latest kodi-platform master (809c5e9)
- Includes latest libcec master (ba9b538, ahead +1)
- Includes latest libnfs master (394b185, ahead +17)
- Includes latest p8-platform master (cee64e9)
- Includes latest addons: inputstream.adaptive (cefcc3d), inputstream.rtmp (ce68b77, +9), peripheral.joystick (c22df4d, +3), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2), pvr.demo (f7bdb99, +1), pvr.dvblink (9d854c8, +2), pvr.dvbviewer (861cd34, +1), pvr.filmon (b2c4b01, +2), pvr.freebox (7fb6d44), pvr.hdhomerun (4465445), pvr.hts (56e95c4, +3), pvr.iptvsimple (1df685c, +2), pvr.mediaportal.tvserver (88db569, +1), pvr.mythtv (2842043), pvr.nextpvr (92d01d1, +5), pvr.njoy (fdffa7d), pvr.octonet (8032f08), pvr.pctv (31d8278), pvr.sledovanitv.cz (07ca551, +3), pvr.stalker (c69e54b, +1), pvr.teleboy (0444314, +1), pvr.vbox (6373a10, +2), pvr.vdr.vnsi (57f8e85, +3), pvr.vuplus (8453707, +2), pvr.waipu (0b40aa2), pvr.wmc (06b0123, +1), pvr.zattoo (7b8cb33), vfs.libarchive (bb9bda3, +12), vfs.rar (394c96e, +22), vfs.sftp (40e4a41, +9)
- Include [env] compare (perma): alsa-lib 1.2.1 update
- Include [env] patch: kodi: add mhupdate
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3667 (perma): libbluray: update to 1.1.2
- Include [env] PR:4023 (perma): config/arm: use eabihf for hard float
- Include [env] PR:4038 (perma): elfutils: install readelf in non-release builds
- Include [env] PR:4058 (perma): libinput: libinput 1.14.3 & xf86-input-libinput 0.29.0
- Include [env] PR:4065 (perma): image: add /etc/environment
- Include [env] PR:4092 (perma): buildsystem: switch to dynamic scheduler
- Include [env] PR:4095 (perma): gettext: build runtime and tools
- Include [env] PR:4098 (perma): linux (Generic/Allwinner/RPi): update to linux-5.4.16
- Revert [env] PR:4010: ffmpeg: rpi ffmpeg patch only for use with rpi kodi (reason: need ffmpeg patches with newclock5)
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:16740 (perma): WIP - [remote] Allow longpress mod for remote keymaps
Build Highlights:
- New 5.4.8 kernel
- LibreELEC-settings: update to LibreELEC-settings-12ba57a
Build Details:
- LibreELEC.tv:
- tools/docker: reorder to match checkdeps (PR:4096, 1 commit, 4 files changed)
- linux (Generic/Allwinner): update to linux-5.4.7 (PR:4030, 20 commits, 11 files changed)
- LibreELEC-settings: update to LibreELEC-settings-12ba57a (PR:4097, 1 commit, 1 file changed)
- XBMC:
- [vfs][addons] fix media view from addon given content (PR:17066, 1 commit, 1 file changed)
- Reset playlist on new file playback (PR:17123, 1 commit, 1 file changed)
- paplayer: avoid race condition that double fires OnPlaybackStarted (PR:17083, 1 commit, 1 file changed)
- vfs.rar:
- [Matrix] update unrar to newest version (PR:50, 13 commits, 194 files changed)
- Added: [env] PR:4095 (perma): gettext: build runtime and tools
- Added: [env] PR:4098 (perma): linux (Generic/Allwinner/RPi): update to linux-5.4.16
Weekly Linux 5.5-rc5 build #0106x:
Generic
Packages disabled/not included:
text:
digital_devices
dvb-latest
crazycat
New LibreELEC.tv Matrix build #0107:
Generic
SHA256 Checksum:
d4e50605875aafc22ebffd94720e9aa3576b3db5b0e9963bc7b24354d0f56e09
(Generic)
text:
# uname -a
Linux NUC 5.4.8 #1 SMP Tue Jan 7 21:03:35 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200107210227-#0107-geda06b1 [Build #0107]
# Kodi version
Kodi (19.0-ALPHA1 Git:13b742e). Platform: Linux x86 64-bit
Based on tip of
XBMC master (13b742e,
- Include [env] PR:4100 (perma): pastekodi: avoid cmp this is installed by system-tools
Build Highlights:
- Update AMD GPU microcode to 19.50
- Fix pastekodi
- [PVR] Improve performance of TriggerRecordingUpdate/TriggerTimerUpdate
Build Details:
- XBMC:
- [windows][depends] Update dependencies for all windows platforms (PR:17143, 2 commits, 22 files changed)
- [PVR] Improve performance of TriggerRecordingUpdate/TriggerTimerUpdate (PR:17140, 1 commit, 2 files changed)
- Updated: [env] PR:4092 (perma): buildsystem: switch to dynamic scheduler
- Updated: [env] PR:4098 (perma): linux (Generic/Allwinner/RPi): update to linux-5.4.16
- Added: [env] PR:4100 (perma): pastekodi: avoid cmp this is installed by system-tools
New LibreELEC.tv Matrix build #0108:
Generic
SHA256 Checksum:
cec5a77102fb6da5c8901da99bdf36d8bd4902781fda0559f41311925c60d9cc
(Generic)
text:
# uname -a
Linux NUC 5.4.8 #2 SMP Wed Jan 8 22:02:09 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200108215512-#0108-gd234b73 [Build #0108]
# Kodi version
Kodi (19.0-ALPHA1 Git:a6d6cbd). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (d234b73,
XBMC master (a6d6cbd,
- Includes latest addons: inputstream.adaptive (cefcc3d), inputstream.rtmp (ce68b77, +9), peripheral.joystick (c22df4d, +3), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2), pvr.demo (f7bdb99, +1), pvr.dvblink (9d854c8, +2), pvr.dvbviewer (861cd34, +1), pvr.filmon (b2c4b01, +2), pvr.freebox (7fb6d44), pvr.hdhomerun (4465445), pvr.hts (56e95c4, +3), pvr.iptvsimple (1df685c, +2), pvr.mediaportal.tvserver (88db569, +1), pvr.mythtv (2842043), pvr.nextpvr (92d01d1, +5), pvr.njoy (fdffa7d), pvr.octonet (8032f08), pvr.pctv (31d8278), pvr.sledovanitv.cz (07ca551, +3), pvr.stalker (c69e54b, +1), pvr.teleboy (0444314, +1), pvr.vbox (6373a10, +2), pvr.vdr.vnsi (57f8e85, +3), pvr.vuplus (8453707, +2), pvr.waipu (0b40aa2), pvr.wmc (06b0123, +1), pvr.zattoo (7b8cb33), vfs.libarchive (bb9bda3, +12), vfs.rar (394c96e, +22), vfs.sftp (c738ea4, +24)
Build Highlights:
- [videoplayer] Fix GetItemsToScan scan in sub-directories
Build Details:
- LibreELEC.tv:
- gettext: build runtime and tools (PR:4095, 2 commits, 2 files changed)
- rpi-eeprom: update to rpi-eeprom-e9290b3 (PR:4102, 1 commit, 1 file changed)
- pastekodi: avoid cmp this is installed by system-tools (PR:4100, 1 commit, 1 file changed)
- config/arm: use eabihf for hard float (PR:4023, 2 commits, 2 files changed)
- buildsystem: add possibility to move the build paths outside the git (PR:3140, 1 commit, 6 files changed)
- image: add /etc/environment (PR:4065, 3 commits, 5 files changed)
- elfutils: install readelf in non-release builds (PR:4038, 1 commit, 3 files changed)
- update_binary-addons: fix unofficial addon bumping (PR:4082, 2 commits, 1 file changed)
- XBMC:
- [videoplayer] Fix GetItemsToScan scan in sub-directories (PR:17036, 1 commit, 1 file changed)
- [PVR] Address regression due to recent PVR recordings change (PR:17154, 1 commit, 1 file changed)
- vfs.sftp:
- [Matrix] cleanup and depends updates (PR:46, 15 commits, 31 files changed)
New LibreELEC.tv Matrix build #0109:
Generic
SHA256 Checksum:
4a982dd5756dc0b7cd53edb811769badc649bd382055486f68feddcb905a1424
(Generic)
text:
# uname -a
Linux NUC 5.4.10 #1 SMP Thu Jan 9 22:06:27 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200109220528-#0109-gd234b73 [Build #0109]
# Kodi version
Kodi (19.0-ALPHA1 Git:87b1f98). Platform: Linux x86 64-bit
Based on tip of
XBMC master (87b1f98,
- Includes latest addons: inputstream.adaptive (cefcc3d), inputstream.rtmp (ce68b77, +9), peripheral.joystick (c22df4d, +3), peripheral.xarcade (51e1a45, +7), pvr.argustv (a8a1ad2), pvr.demo (f7bdb99, +1), pvr.dvblink (9d854c8, +2), pvr.dvbviewer (861cd34, +1), pvr.filmon (b2c4b01, +2), pvr.freebox (7fb6d44), pvr.hdhomerun (4465445), pvr.hts (56e95c4, +3), pvr.iptvsimple (1df685c, +2), pvr.mediaportal.tvserver (88db569, +1), pvr.mythtv (5d79dc7, +4), pvr.nextpvr (92d01d1, +5), pvr.njoy (fdffa7d), pvr.octonet (8032f08), pvr.pctv (31d8278), pvr.sledovanitv.cz (07ca551, +3), pvr.stalker (c69e54b, +1), pvr.teleboy (0444314, +1), pvr.vbox (6373a10, +2), pvr.vdr.vnsi (57f8e85, +3), pvr.vuplus (8453707, +2), pvr.waipu (0b40aa2), pvr.wmc (06b0123, +1), pvr.zattoo (7b8cb33), vfs.libarchive (bb9bda3, +12), vfs.rar (394c96e, +22), vfs.sftp (c738ea4, +24)
- Include [env] PR:4106 (perma): mesa: update to mesa-19.3.2
Build Highlights:
- New 5.4.10 kernel
- mesa: update to mesa-19.3.2
Build Details:
- XBMC:
- Fix HEAD Content-Length (PR:17159, 1 commit, 1 file changed)
- pvr.mythtv:
- reuse string 30062 for 'Allow backend shutdown' (d7e63e1)
- sync upstream cppmyth (2.13.0) (49e6f02)
- fix allow backend shutdown on reconnect (2aa30af)
- bump version 6.2.6 (5d79dc7)
- Added: [env] PR:4106 (perma): mesa: update to mesa-19.3.2
Download servers are currently inaccessible (under investigation).
(Turned out to be a local ISP issue)
Strange no problem for me
OK could just be an issue with my ISP in that case!
Edit: issue resolved by my ISP.
New LibreELEC.tv Matrix build #0110:
Generic
SHA256 Checksum:
11d099e4fc36e3d1132f3ecab93a8fb54dc43b2a00ac481f29fc9c476ee95ad5
(Generic)
text:
# uname -a
Linux NUC 5.4.10 #2 SMP Sat Jan 11 02:35:44 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200111023308-#0110-gf59b99c [Build #0110]
# Kodi version
Kodi (19.0-ALPHA1 Git:6e017a3). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (f59b99c,
XBMC master (6e017a3,
- Include [env] PR:4104 (perma): make: update to v4.3
- Include [env] PR:4107 (perma): kernel-overlays: move volatile runtime data to /run
- Include [env] PR:4108 (perma): init: drop support for loading modules in initramfs
Build Highlights:
- make: update to v4.3
- kernel-overlays: move volatile runtime data to /run
Build Details:
- LibreELEC.tv:
- mesa: update to mesa-19.3.2 (PR:4106, 1 commit, 1 file changed)
- XBMC:
- [PVR] EPG Guide window: Prevent scrolling of the grid if causing action was not user-initiated (PR:17158, 1 commit, 3 files changed)
- Implement Apple TV Platform (PR:16860, 9 commits, 154 files changed)
- [Buildsteps] Fix URL for list of Kodi mirrors (PR:16598, 1 commit, 1 file changed)
- [windows][depends] Fix missing algorithms in pycryptodome (PR:17157, 1 commit, 5 files changed)
- Added: [env] PR:4104 (perma): make: update to v4.3
- Added: [env] PR:4107 (perma): kernel-overlays: move volatile runtime data to /run
- Added: [env] PR:4108 (perma): init: drop support for loading modules in initramfs
New LibreELEC.tv Matrix build #0111:
Generic
SHA256 Checksum:
1ea055796f61bbe2fd1802c102aff8cd890cd2985e9bfbd5ba072f8cd6139d78
(Generic)
text:
# uname -a
Linux NUC 5.4.10 #4 SMP Sat Jan 11 23:33:49 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200111233139-#0111-g3953383 [Build #0111]
# Kodi version
Based on tip of
LibreELEC.tv master (3953383,
Build Highlights:
- Nothing today
Build Details:
- LibreELEC.tv:
- Allwinner: Sort Linux patches (PR:4099, 1 commit, 10 files changed)
