Can those with the audio issue also try 5.6-rc6 _without_ any blacklist workaround (ie. confirm audio is broken with a pre-#0316 build, then update to the
5.6-rc6 release)? It would be useful to know if there is any progress in 5.6 which might make the workaround added in #0316 (for use with 5.5.x) unnecessary once we switch to 5.6.0. We had one person on the LE team indicate that 5.6-rc6 is working fine without any workaround, but given the random nature of this issue that could be by chance.
New LibreELEC.tv Matrix build #0317:
Generic
(Supercedes previous build)
SHA256 Checksum:
a40e043e7d726657e831ba2b0e89b111cdf90da0c066d90fb1ac979bc5ce89f8
(Generic)
text:
# uname -a
Linux NUC 5.5.9 #1 SMP Tue Mar 17 21:43:28 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200317214242-#0317-g9542570 [Build #0317]
# Kodi version
Kodi (19.0-ALPHA1 Git:3a9c94d). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (9542570,
changelog) and tip of
XBMC master (3a9c94d,
- Includes latest kodi-platform master (809c5e9)
- Includes latest libcec master (ba9b538, ahead +1)
- Includes latest libnfs master (394b185, ahead +17)
- Includes latest p8-platform master (cee64e9)
- Includes latest addons: inputstream.adaptive (97f2d96), inputstream.ffmpegdirect (cf1dc46), inputstream.rtmp (02d6a0d), peripheral.joystick (1e96d24, +1), peripheral.xarcade (51e1a45), pvr.argustv (e1710ff, +1), pvr.demo (4a7a953, +6), pvr.dvblink (9e7e219, +9), pvr.dvbviewer (1ef3854, +3), pvr.filmon (80c9c84, +1), pvr.freebox (dd0db19, +4), pvr.hdhomerun (024aba0, +1), pvr.hts (8440e59, +1), pvr.iptvsimple (8cd1eca, +1), pvr.mediaportal.tvserver (f21fc8e, +2), pvr.mythtv (27fbcc2, +4), pvr.nextpvr (10ae243, +9), pvr.njoy (69224ee, +5), pvr.octonet (237362e, +2), pvr.pctv (ace1b52, +5), pvr.sledovanitv.cz (cfd9e1e, +16), pvr.stalker (e972981, +1), pvr.teleboy (b4c6756, +2), pvr.vbox (d4e1e53, +11), pvr.vdr.vnsi (72bd049, +1), pvr.vuplus (5c3d0d0, +1), pvr.waipu (aa83ee0, +1), pvr.wmc (ac042b2, +1), pvr.zattoo (abef64f, +3), vfs.libarchive (fa3f51b, +2), vfs.rar (723196b, +2), vfs.sftp (d1dc0a7, +3)
- Include [env] compare (perma): linux (Generic): enable Marvell SDIO and USB WiFi support as module
- Include [env] patch: kodi: add mhupdate
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:4201 (perma): linux: bail when config options are missing
- Include [env] PR:4237 (perma): linux (Generic/Allwinner): update to linux-5.5.13
- Include [env] PR:4242 (perma): rpi-eeprom: update to rpi-eeprom-<next>
- Include [env] PR:4243 (perma): linux (RPi): update to linux-5.4.28
- Include [env] PR:4255 (perma): kodi: next update (end of March 2020?)
- Include [env] PR:4261 (perma): add RemainAfterExit=yes to our oneshot systemd services
- Include [env] PR:4262 (perma): gcc: update to gcc-9.3.0
- Include [env] PR:4266 (perma): bluez: update to bluez-5.54
- Include [env] PR:4268 (perma): alsa-lib: use hda_intel driver on Intel boards with a DSP
- Revert [env] PR:4010: ffmpeg: rpi ffmpeg patch only for use with rpi kodi (reason: need ffmpeg patches with newclock5)
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:446 (perma): Fix pointer to freed memory in EPG_TAG.strFirstAired. (pvr.hts)
- Include [pkg] PR:495 (perma): USBCECAdapterDetection: Only scan tty (libcec)
- Include [pkg] PR:16168 (perma): sse4: build in support instead of making a shared library
- Include [pkg] PR:16578 (perma): TexturePacker: fix for 32-bit systems
- Include [pkg] PR:16740 (perma): WIP - [remote] Allow longpress mod for remote keymaps
- Include [pkg] PR:17046 (perma): changed: Move filecache buffering logic from CDVDInputStreamFile to CFile
Build Highlights:
- Update PVR API 6.2.0
- [Matrix] fix seek problems (vfs.rar)
- remove support for 'XBMC.' prefixed built-in commands
Build Details:
- XBMC:
- remove support for 'XBMC.' prefixed built-in commands (PR:17457, 1 commit, 4 files changed)
- [Estuary] re-add support for the autocomplete plugin (PR:17453, 1 commit, 2 files changed)
- [guilib] add listitem.uniqueid() infolabel (PR:17340, 1 commit, 3 files changed)
- [cmake] fix dav1d spelling (PR:17490, 1 commit, 1 file changed)
- [vfs][addons] fix title show of compressed package dir (PR:17484, 1 commit, 1 file changed)
- [PVR] Add support for firstAired tag via PVR Recordings (PR:17153, 1 commit, 5 files changed)
- [PVR] Convert EPG First Aired from time_t to date string (PR:17192, 1 commit, 8 files changed)
- AudioTrack: Properly use TimeStamp results in delay not in latency (PR:17504, 3 commits, 1 file changed)
- pvr.argustv:
- Update PVR API 6.2.0 (PR:98, 1 commit, 3 files changed)
- pvr.demo:
- Update PVR API 6.2.0 (PR:75, 1 commit, 2 files changed)
- pvr.dvblink:
- Update PVR API 6.2.0 (PR:128, 1 commit, 4 files changed)
- pvr.dvbviewer:
- Update PVR API 6.2.0 (PR:84, 1 commit, 3 files changed)
- Fix alignment because apparently @phunkyfish didn't care.. (1ef3854)
- pvr.filmon:
- Update PVR API 6.2.0 (PR:95, 1 commit, 3 files changed)
- pvr.freebox:
- Update PVR API 6.2.0 (PR:34, 1 commit, 2 files changed)
- pvr.hdhomerun:
- Update PVR API 6.2. (PR:91, 1 commit, 3 files changed)
- pvr.hts:
- API Change for iEpisodePartNumber EPG_TAG default value (PR:445, 1 commit, 4 files changed)
- pvr.iptvsimple:
- PVR API 6.2.0 (PR:339, 1 commit, 4 files changed)
- pvr.mediaportal.tvserver:
- Update PVR API 6.2.0 (PR:114, 1 commit, 4 files changed)
- pvr.mythtv:
- Update PVR API 6.2.0 (PR:140, 1 commit, 4 files changed)
- sync upstream cppmyth (2.14.0) (5d5f5b2)
- backend provides airdate as string (20864dd)
- bump version 6.3.0 (27fbcc2)
- pvr.nextpvr:
- V4.3.3 Update PVR API 6.2.0 (#113) (10ae243)
- pvr.njoy:
- Update PVR API 6.2.0 (PR:54, 1 commit, 2 files changed)
- pvr.octonet:
- Update PVR API 6.2.0 (PR:37, 1 commit, 2 files changed)
- pvr.pctv:
- Update PVR API 6.2.0 (PR:70, 1 commit, 3 files changed)
- pvr.sledovanitv.cz:
- pvr.stalker:
- Update PVR API 6.2.0 (PR:131, 1 commit, 5 files changed)
- pvr.teleboy:
- Update PVR API 6.2.0 (PR:45, 1 commit, 2 files changed)
- pvr.vbox:
- PVR API 6.2.0 and remove custom reminders impl (PR:233, 3 commits, 11 files changed)
- pvr.vdr.vnsi:
- Update PVR API 6.2.0 (PR:127, 1 commit, 3 files changed)
- pvr.vuplus:
- PVR API 6.2.0 (PR:275, 1 commit, 8 files changed)
- pvr.waipu:
- Update PVR API 6.2.0 (PR:61, 1 commit, 2 files changed)
- pvr.wmc:
- Update PVR API 6.2.0 (PR:76, 1 commit, 3 files changed)
- pvr.zattoo:
- vfs.rar:
- [Matrix] fix seek problems (PR:66, 2 commits, 2 files changed)
- Added: [pkg] PR:446 (perma): Fix pointer to freed memory in EPG_TAG.strFirstAired. (pvr.hts)
(2020-03-17, 22:49)Milhouse Wrote: [ -> ]Can those with the audio issue also try 5.6-rc6 _without_ any blacklist workaround (ie. confirm audio is broken with a pre-#0316 build, then update to the 5.6-rc6 release)? It would be useful to know if there is any progress in 5.6 which might make the workaround added in #0316 (for use with 5.5.x) unnecessary once we switch to 5.6.0. We had one person on the LE team indicate that 5.6-rc6 is working fine without any workaround, but given the random nature of this issue that could be by chance.
Yes, we can
upgrading from #315 to #0315
x (from Kernel 5.5.9 to 5.6-rc6) fixes the audio issue too.
on an Intel NUC
8i3BEH (
Bean Canyon) "HD Audio DSP" in the bios was during the upgrade always Enabled.
New LibreELEC.tv Matrix build #0318:
Generic
SHA256 Checksum:
a8c7fa4aa71d9ee6fefedd1dd26f1c8fc803ae2765bbf3dbe58fee43e5092dab
(Generic)
text:
# uname -a
Linux NUC 5.5.9 #1 SMP Wed Mar 18 21:04:25 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200318210338-#0318-g9542570 [Build #0318]
# Kodi version
Kodi (19.0-ALPHA1 Git:809e36a). Platform: Linux x86 64-bit
Based on tip of
XBMC master (809e36a,
- Includes latest addons: inputstream.adaptive (97f2d96), inputstream.ffmpegdirect (cf1dc46), inputstream.rtmp (02d6a0d), peripheral.joystick (1e96d24, +1), peripheral.xarcade (51e1a45), pvr.argustv (e1710ff, +1), pvr.demo (4a7a953, +6), pvr.dvblink (9e7e219, +9), pvr.dvbviewer (1ef3854, +3), pvr.filmon (80c9c84, +1), pvr.freebox (dd0db19, +4), pvr.hdhomerun (024aba0, +1), pvr.hts (e4680f0, +2), pvr.iptvsimple (8cd1eca, +1), pvr.mediaportal.tvserver (f21fc8e, +2), pvr.mythtv (eda5339, +6), pvr.nextpvr (10ae243, +9), pvr.njoy (69224ee, +5), pvr.octonet (237362e, +2), pvr.pctv (ace1b52, +5), pvr.sledovanitv.cz (cfd9e1e, +16), pvr.stalker (e972981, +1), pvr.teleboy (b4c6756, +2), pvr.vbox (d4e1e53, +11), pvr.vdr.vnsi (72bd049, +1), pvr.vuplus (5c3d0d0, +1), pvr.waipu (aa83ee0, +1), pvr.wmc (ac042b2, +1), pvr.zattoo (abef64f, +3), vfs.libarchive (fa3f51b, +2), vfs.rar (723196b, +2), vfs.sftp (d1dc0a7, +3)
Build Highlights:
- Minors
Build Details:
- XBMC:
- Add SVG mimetype (PR:15961, 1 commit, 1 file changed)
- pvr.hts:
- Fix pointer to freed memory in EPG_TAG.strFirstAired. (PR:446, 1 commit, 5 files changed)
- pvr.mythtv:
(2020-03-18, 03:56)sixpack58 Wrote: [ -> ]Yes, we can
upgrading from #315 to #0315x (from Kernel 5.5.9 to 5.6-rc6) fixes the audio issue too.
on an Intel NUC 8i3BEH (Bean Canyon) "HD Audio DSP" in the bios was during the upgrade always Enabled.
Great, many thanks. It would be terrific if we could get at least another 2 or 3 confirmations that 5.6-rc6 now fixes this issue - the original failure is somewhat random in nature, and there have been several attempts at fixing it in the pre-5.6 kernel (none of which succeeded) hence my uncertainty regarding any fix in 5.6-rcX!
New LibreELEC.tv Matrix build #0319:
Generic
SHA256 Checksum:
fb078cae1726cb14e3742ce24ae15140306e3a3bc8ebc5aba7ccc7bb53a4a597
(Generic)
text:
# uname -a
Linux NUC 5.5.9 #1 SMP Thu Mar 19 22:56:05 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200319225516-#0319-g9542570 [Build #0319]
# Kodi version
Kodi (19.0-ALPHA1 Git:bfbf6d9). Platform: Linux x86 64-bit
Based on tip of
XBMC master (bfbf6d9,
- Includes latest addons: inputstream.adaptive (97f2d96), inputstream.ffmpegdirect (48287bb, +1), inputstream.rtmp (02d6a0d), peripheral.joystick (1e96d24, +1), peripheral.xarcade (51e1a45), pvr.argustv (e1710ff, +1), pvr.demo (4a7a953, +6), pvr.dvblink (9e7e219, +9), pvr.dvbviewer (1ef3854, +3), pvr.filmon (80c9c84, +1), pvr.freebox (dd0db19, +4), pvr.hdhomerun (024aba0, +1), pvr.hts (e4680f0, +2), pvr.iptvsimple (8cd1eca, +1), pvr.mediaportal.tvserver (f21fc8e, +2), pvr.mythtv (eda5339, +6), pvr.nextpvr (10ae243, +9), pvr.njoy (69224ee, +5), pvr.octonet (237362e, +2), pvr.pctv (ace1b52, +5), pvr.sledovanitv.cz (cfd9e1e, +16), pvr.stalker (e972981, +1), pvr.teleboy (b4c6756, +2), pvr.vbox (d4e1e53, +11), pvr.vdr.vnsi (72bd049, +1), pvr.vuplus (5c3d0d0, +1), pvr.waipu (aa83ee0, +1), pvr.wmc (ac042b2, +1), pvr.zattoo (abef64f, +3), vfs.libarchive (fa3f51b, +2), vfs.rar (723196b, +2), vfs.sftp (d1dc0a7, +3)
- Include [env] PR:4269 (perma): mesa: update to mesa-20.0.2
- Include [pkg] PR:12100 (perma): Increase commbreakautowait and commbreakautowind max seconds to 60
Build Highlights:
- mesa: update to mesa-20.0.2
- [Fix]Wake from screensaver on PlayFile()
- Increase commbreakautowait and commbreakautowind max seconds to 60
Build Details:
- XBMC:
- [Estuary] Added Embuary Info features to home categories (PR:17518, 1 commit, 3 files changed)
- [Fix] Trival clean-up of CPlaylistOperations::Insert (PR:17500, 1 commit, 1 file changed)
- [Fix]Wake from screensaver on PlayFile() (PR:17497, 1 commit, 1 file changed)
- inputstream.ffmpegdirect:
- Fix tvOS build (PR:22, 1 commit, 5 files changed)
- Added: [env] PR:4269 (perma): mesa: update to mesa-20.0.2
- Added: [pkg] PR:12100 (perma): Increase commbreakautowait and commbreakautowind max seconds to 60
double post, caused by logoff during editing => delete
(2020-03-20, 00:49)Milhouse Wrote: [ -> ]Great, many thanks. It would be terrific if we could get at least another 2 or 3 confirmations that 5.6-rc6 now fixes this issue - the original failure is somewhat random in nature, and there have been several attempts at fixing it in the pre-5.6 kernel (none of which succeeded) hence my uncertainty regarding any fix in 5.6-rcX!
what holds you off to place a call in this thread:
https://forum.libreelec.tv/thread/21536-...and-audio/
there are all or
most people together
with different NUC's which suffer from this bug, too.
I guess it's the best audience benefiting at most to get this bug fixed.
It would be wise to give an
instruction at hand
how to run builds from an usb stick, otherwise they would be afraid to damage their installs and reject the call/tests.
Please place the instruction on page 1 in this thread, it's missing there - for my taste -
@"sixpack58"
Set your HTPC to boot from USB as the primary choice. Then...
1. Bootup LibreELEC USB thumbdrive created with the “LibreELEC USB-SD Creator” app from the LibreELEC website (or make it with Rufus or your preferred software tool).
2. After booting you am presented with a menu with 3 choices: Install, Run, or Live.
- Install installs LE on the hardrive of the HTPC, wiping out any existing OS's and files.
- Run installs LE onto the same USB thumbdrive in a "persistent" state, and saves changes such as libraries and add-ons. Additionally, it makes the USB thumbdrive boot to the "Run" condition by default from then on. On a USB 3.0 device in a USB 3.0 port it is as fast as a native installation.
- Live runs LE from the USB thumbdrive but I don't think it is persistent, doesn't save any changes you make, libraries, add-ons, etc.
So type Run and hit Enter before the Installation timer runs out.
Wait for LE to do it's thing, your HTPC will reboot into LE, running from the USB thumbdrive.
This method uses the HTPC's ram and hardware, but doesn't make any changes to the device's hard drive.
Milhouse
5.6-RC6 BUILD #0315x test drive on my NUC8i5BEK:
1. Turned Intel HD-DSP back on in BIOS.
2. Installed LE 9.2.1 (run from USB thumbdrive) - confirmed no audio - log file
http://ix.io/2eN2
3. Updated to #315 - confirmed no audio - log file
http://ix.io/2eNw
4. Updated to 315x -
audio available - log file
http://ix.io/2eNy
(2020-03-20, 22:27)sixpack58 Wrote: [ -> ]what holds you off to place a call in this thread:
I'm fairly sure that we'd end up trashing working systems thanks to Python3 so that's not really a mess I want to get involved with right now... the vast majority of testers in this thread are using Intel CPUs with integrated GPUs (ie. NUCs) so we should have been able to find a couple of people able to test #0315, #0315x and #0316 but whatever... we have two confirmed reports so I'll drop the workaround from 5.6-rc builds.
New LibreELEC.tv Matrix build #0320:
Generic
SHA256 Checksum:
dfe3872532ec3145ba1c8672dc01a0278a154ccfb7e071195c5b091619568a1d
(Generic)
text:
# uname -a
Linux NUC 5.5.9 #1 SMP Fri Mar 20 21:59:43 GMT 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200320215855-#0320-gf311356 [Build #0320]
# Kodi version
Kodi (19.0-ALPHA1 Git:4226dc1). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (f311356,
XBMC master (4226dc1,
Build Highlights:
- [Music]Sorting with limits in database rather than memory
Build Details:
- LibreELEC.tv:
- NXP: linux: remove uneeded patch to allow build to compile (PR:4252, 1 commit, 2 files changed)
- XBMC:
- [gbm] add CBufferObjectFactory and CDumbBufferObject (PR:17403, 10 commits, 14 files changed)
- [Music]Sorting with limits in database rather than memory (PR:16971, 1 commit, 8 files changed)
- [Fix]Import song history match when have multiple releases of same album (PR:17433, 1 commit, 1 file changed)
- Updated: [env] PR:4242 (perma): rpi-eeprom: update to rpi-eeprom-<next>
- Updated: [env] PR:4243 (perma): linux (RPi): update to linux-5.4.28
(2020-03-21, 00:47)Milhouse Wrote: [ -> ]Thanks @whysoserious, @sixpack58 (and also JoeAverage) - looks like 5.6-rc might have fixed the audio issue.
Don't hold your breath on that, this could be pure coincidence (as we had in LE9.2). I haven't noticed any changes between 5.5 and 5.6-rc that would change legacy/sst/sof probing.
Long-term goal seems to be to move to the SOF drivers (with opensource DSP code) but we don't have them enabled in LE and don't ship the SOF firmwares either.
So, for the time being, it may be best to default to hda-intel (as we don't ship sst firmwares either).
so long,
Hias
