(2020-04-18, 22:53)Milhouse Wrote: [ -> ] (2020-04-18, 11:42)brotaxt Wrote: [ -> ]I get sound with activated HD Audio DSP on my Intel Nuc now.
After activating I wonder what is the HD Audio DSP needed for? Everything worked without the DSP!?
Greetings & many thanks in advance!
I'm not entirely sure, to be honest - my Skylake NUC isn't connected to an HD capable audio device (my computer monitor only has stereo output!) so I'm not currently able to test that.
In your thread you say you don't have the HD-Audio passthrough options in the Kodi settings menu, do you have them now with the addition of DSP firmware? Presumably the HD hardware isn't initialising correctly when the DSP firmware is missing.
Also, it shouldn't be necessary to blacklist snd_soc_skl audio hardware any longer as this should now be fixed in kernel 5.6-rc6. For libreelec-9.2 (which uses 5.1.y) we've added a workaround that automatically blacklists snd_soc_skl.
Yes, everything works as expected now. The hd audio passthrough options are all available and are working flawless.
I removed the snd_soc_skl module from blacklist and activated the hd Audi DSP in the bios.
The only thing that's not working is the playback of Netflix streams with activated hevc profiles. And I can't figure out why. I don't see any error messages in the debug log, but the playback just won't start. Debug log:
https://paste.kodi.tv/koxeboyoli.kodi
Does anyone have an idea why the playback is not working?
Greetings!
(2020-04-19, 10:12)brotaxt Wrote: [ -> ]Does anyone have an idea why the playback is not working?
Not sure.
I see from your
Netflix issue that the add-on maintainer thinks this is a Kodi core issue, which may be correct - @
lrusak any thoughts?
(2020-04-19, 05:11)Milhouse Wrote: [ -> ]Either the upgrade is not successful for some reason, or you're somehow (randomly) booting off multiple drives. A logfile could help, but in this case the latest zip file from the Samba "Logfiles" share might be more useful as it will include all hardware details.
for what it's worth:
I successfully upgrades from ~ #415 to #418 today night on an USB3-Stick.
I would like to mention
a) that after the first stick-Install the "boot mimik" remains . It's what the USB-creator puts on the stick (all modes: install (default selected), run, live, ...) => manual cleanage of /flash/syslinux.cfg
b) that the internal drive is default mounted under /var/media/ => a script with unmount
maybe the OP runs here in trouble somehow ?
New LibreELEC.tv Matrix build #0419:
Generic
(Supercedes previous build)
SHA256 Checksum:
f5acf5608a3c4279f6fc09ea22b6dc99611f5f0713ef7d4879a231d9e403a19e
(Generic)
text:
# uname -a
Linux NUC 5.6.5 #1 SMP Sun Apr 19 22:10:23 BST 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200419220923-#0419-g9850f95 [Build #0419]
# Kodi version
Starting Kodi (19.0-ALPHA1 Git:b164c7f). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (9850f95,
changelog) and tip of
XBMC master (b164c7f,
- Includes latest kodi-platform master (809c5e9)
- Includes latest libcec master (72ae683, ahead +6)
- Includes latest libnfs master (394b185, ahead +17)
- Includes latest p8-platform master (cee64e9)
- Includes latest addons: inputstream.adaptive (ca2fd36, +5), inputstream.ffmpegdirect (bbc212d), inputstream.rtmp (d4b259f), peripheral.joystick (31a0738, +2), peripheral.xarcade (51e1a45), pvr.argustv (07cdbc7), pvr.demo (949f23a), pvr.dvblink (ceefaa4), pvr.dvbviewer (4bc6cf8), pvr.filmon (3f0780a), pvr.freebox (a6d7e6c, +3), pvr.hdhomerun (a8b8a92), pvr.hts (28d25b4), pvr.iptvsimple (bf2165a, +3), pvr.mediaportal.tvserver (4561901), pvr.mythtv (ec76ced), pvr.nextpvr (aab6115, +1), pvr.njoy (49af75b), pvr.octonet (50386e1), pvr.pctv (2d58229), pvr.sledovanitv.cz (e4fdc73), pvr.stalker (2b4e270), pvr.teleboy (956486e), pvr.vbox (9678536), pvr.vdr.vnsi (42a7fe2), pvr.vuplus (0efa417), pvr.waipu (30b911d), pvr.wmc (cdb3843), pvr.zattoo (26b9d6f), vfs.libarchive (a86e0f5), vfs.rar (0f9ab01), vfs.sftp (1ca3222)
- Include [env] patch: kodi: add mhupdate
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:4201 (perma): linux: bail when config options are missing
- Include [env] PR:4242 (perma): rpi-eeprom: update to rpi-eeprom-<next>
- Include [env] PR:4261 (perma): add RemainAfterExit=yes to our oneshot systemd services
- Include [env] PR:4268 (perma): alsa-lib: use hda_intel driver on Intel boards with a DSP
- Include [env] PR:4271 (perma): Support cross-compile on aarch64 platform
- Include [env] PR:4283 (perma): libcec: update to libcec-next
- Include [env] PR:4285 (perma): xorg-server: update to xorg-server-1.20.8 (and friends)
- Include [env] PR:4286 (perma): linux (RPi): update to linux-5.4.34
- Include [env] PR:4287 (perma): gnutls: update to 3.6.13
- Include [env] PR:4288 (perma): RPi4: switch to KMS driver and enable v4l2 HEVC decoding
- Include [env] PR:4291 (perma): linux (Generic/Allwinner): update to linux-5.6.6
- Include [env] PR:4325 (perma): busybox: update to busybox-9aa751b; enable tac
- Include [env] PR:4326 (perma): MarkupSafe: bump to 1.1.1
- Include [env] PR:4329 (perma): kernel-firmware: use copy-firmware.sh
- Include [env] PR:4330 (perma): bison: update to bison-3.5.4; nano-4.9.2
- Include [env] PR:4333 (perma): libva: update to libva-2.7.1
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:13 (perma): Updated coexistence param for post-176 firmware (brcmfmac_sdio-firmware-rpi)
- Include [pkg] PR:420 (perma): Matrix API change to v2.2.0 - Allows upto 256 streams, useful for netflix etc. (inputstream.adaptive)
- Include [pkg] PR:16740 (perma): WIP - [remote] Allow longpress mod for remote keymaps
- Include [pkg] PR:17046 (perma): changed: Move filecache buffering logic from CDVDInputStreamFile to CFile
- Include [pkg] PR:17529 (perma): Re-introduce "input.enablejoystick" setting
- Include [pkg] PR:17562 (perma): Alphanumeric sorting improvements: accented letters and brackets
- Include [pkg] PR:17692 (perma): Correct on-screen keyboard behaviour for Arabic characters
- Include [pkg] PR:17701 (perma): Bug Fixes (2x addon related. 1x quite serious file system related)
Build Highlights:
- kodi: Correct on-screen keyboard behaviour for Arabic characters
- kodi: add-on install bug fixes (2nd attempt)
Build Details:
- LibreELEC.tv:
- kodi: next update (end of March 2020?) (PR:4255, 13 commits, 8 files changed)
- kodi binary addons: update to 2020-04-18 Matrix versions (PR:4332, 1 commit, 33 files changed)
- XBMC:
- Add "Portuguese (Brazil)" for audio and subtitles streams (ISO-639-2) (PR:17689, 1 commit, 1 file changed)
- [python] Support multi-line text in dialogs (PR:17684, 1 commit, 1 file changed)
- Add error handling code for some external APIs (PR:17458, 1 commit, 2 files changed)
- Clean up some music library related compiler warnings (PR:17694, 1 commit, 2 files changed)
- Fixed checking if proxy and username pass are empty (PR:17338, 1 commit, 1 file changed)
- [settings/lib] implement missing CSettingList/Int/String::MergeDetails() (PR:17503, 1 commit, 1 file changed)
- [windowing/gbm] Select best CRTC+planes option (PR:16237, 2 commits, 3 files changed)
- TexturePacker: fix for 32-bit systems (PR:16578, 1 commit, 2 files changed)
- [tvos] Runtime fixup after spdlog (PR:17697, 1 commit, 1 file changed)
- pvr.iptvsimple:
- Add support for catchup stream granularity property for ffmpegdirect (PR:359, 3 commits, 5 files changed)
- Updated: [env] PR:4288 (perma): RPi4: switch to KMS driver and enable v4l2 HEVC decoding
- Updated: [env] PR:4329 (perma): kernel-firmware: use copy-firmware.sh
- Updated: [pkg] PR:17562 (perma): Alphanumeric sorting improvements: accented letters and brackets
- Added: [pkg] PR:17692 (perma): Correct on-screen keyboard behaviour for Arabic characters
- Added: [pkg] PR:17701 (perma): Bug Fixes (2x addon related. 1x quite serious file system related)
Weekly Linux 5.7-rc2 build #0419x:
Generic
Known issues:
text:
crazycat and dvb-latest are disabled
New LibreELEC.tv Matrix build #0420:
Generic
SHA256 Checksum:
451cb554d2fba749b4364aa3301bc3e9aa9b21197108a1f56e13c5e11c72c3ea
(Generic)
text:
# uname -a
Linux nuc 5.6.5 #1 SMP Mon Apr 20 22:27:12 BST 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200420222555-#0420-g9850f95 [Build #0420]
# Kodi version
Starting Kodi (19.0-ALPHA1 Git:9fab130). Platform: Linux x86 64-bit
Based on tip of
XBMC master (9fab130,
- Includes latest addons: inputstream.adaptive (ca2fd36, +5), inputstream.ffmpegdirect (bbc212d), inputstream.rtmp (d4b259f), peripheral.joystick (31a0738, +2), peripheral.xarcade (51e1a45), pvr.argustv (07cdbc7), pvr.demo (949f23a), pvr.dvblink (ceefaa4), pvr.dvbviewer (4bc6cf8), pvr.filmon (3f0780a), pvr.freebox (a6d7e6c, +3), pvr.hdhomerun (a8b8a92), pvr.hts (28d25b4), pvr.iptvsimple (d302ce6, +4), pvr.mediaportal.tvserver (4561901), pvr.mythtv (ec76ced), pvr.nextpvr (aab6115, +1), pvr.njoy (49af75b), pvr.octonet (50386e1), pvr.pctv (2d58229), pvr.sledovanitv.cz (e4fdc73), pvr.stalker (2b4e270), pvr.teleboy (956486e), pvr.vbox (9678536), pvr.vdr.vnsi (42a7fe2), pvr.vuplus (0efa417), pvr.waipu (30b911d), pvr.wmc (cdb3843), pvr.zattoo (26b9d6f), vfs.libarchive (a86e0f5), vfs.rar (0f9ab01), vfs.sftp (1ca3222)
- Include [pkg] PR:17705 (perma): Remove onAbortRequested python callback functionality
- Include [pkg] PR:17713 (perma): [VP] Postpone DMX_SPECIALID_STREAMCHANGE until player is started
Build Highlights:
- kodi: [repository.xbmc.org] Define assets and bump addon version
- kodi: Remove onAbortRequested python callback functionality
- kodi: [VP] Postpone DMX_SPECIALID_STREAMCHANGE until player is started
Build Details:
- XBMC:
- [GBM] CVideoLayerBridgeDRMPRIME: query supported values before setting them (PR:17650, 1 commit, 3 files changed)
- [repository.xbmc.org] Define assets and bump addon version (PR:17704, 1 commit, 1 file changed)
- [estuary] optionally show date/duration if recordings sort mode is size or duration (PR:17691, 1 commit, 2 files changed)
- [cmake] change warnings to status as it's only for indication (PR:17657, 1 commit, 1 file changed)
- [cmake] addons support multiple regex arguments for ADDONS_TO_BUILD (PR:17699, 1 commit, 1 file changed)
- pvr.iptvsimple:
- Install ffmpegdirect dependency by default (PR:360, 1 commit, 3 files changed)
- Updated: [env] PR:4286 (perma): linux (RPi): update to linux-5.4.34
- Updated: [pkg] PR:17692 (perma): Correct on-screen keyboard behaviour for Arabic characters
- Added: [pkg] PR:17705 (perma): Remove onAbortRequested python callback functionality
- Added: [pkg] PR:17713 (perma): [VP] Postpone DMX_SPECIALID_STREAMCHANGE until player is started
New LibreELEC.tv Matrix build #0421:
Generic
SHA256 Checksum:
8a53812aab62e228d66970e9d6f0f289502df584af1250b16d66df92dcfe341d
(Generic)
text:
# uname -a
Linux NUC 5.6.6 #1 SMP Wed Apr 22 00:13:26 BST 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200422001139-#0421-g9850f95 [Build #0421]
# Kodi version
Starting Kodi (19.0-ALPHA1 Git:92dea00). Platform: Linux x86 64-bit
Based on tip of
XBMC master (92dea00,
- Includes latest addons: inputstream.adaptive (ca2fd36, +5), inputstream.ffmpegdirect (bbc212d), inputstream.rtmp (d4b259f), peripheral.joystick (31a0738, +2), peripheral.xarcade (51e1a45), pvr.argustv (07cdbc7), pvr.demo (949f23a), pvr.dvblink (ceefaa4), pvr.dvbviewer (4bc6cf8), pvr.filmon (3f0780a), pvr.freebox (a6d7e6c, +3), pvr.hdhomerun (a8b8a92), pvr.hts (28d25b4), pvr.iptvsimple (f4d9cf2, +5), pvr.mediaportal.tvserver (4561901), pvr.mythtv (ec76ced), pvr.nextpvr (aab6115, +1), pvr.njoy (49af75b), pvr.octonet (50386e1), pvr.pctv (2d58229), pvr.sledovanitv.cz (e4fdc73), pvr.stalker (2b4e270), pvr.teleboy (956486e), pvr.vbox (9678536), pvr.vdr.vnsi (42a7fe2), pvr.vuplus (0efa417), pvr.waipu (30b911d), pvr.wmc (cdb3843), pvr.zattoo (ce5d72e, +1), vfs.libarchive (a86e0f5), vfs.rar (0f9ab01), vfs.sftp (1ca3222)
- Include [env] PR:4340 (perma): libzip: update to libzip-1.6.1
- Include [env] PR:4341 (perma): dbus, systemd: fix duplicate tmpfiles and missing groups
- Include [pkg] PR:17718 (perma): Fix crash on exit.
- Include [pkg] PR:17720 (perma): [settings] don't load setting values twice
- Revert [pkg] PR:17458: Add error handling code for some external APIs (reason: crashes on startup)
Build Highlights:
- New 5.6.6 kernel
- kodi: Fix crash on exit.
- kodi: [settings] don't load setting values twice
- kodi: Revert PR causing startup crash
Build Details:
- XBMC:
- [docs] add link to PRs in needed of review in contributing doc (PR:17712, 1 commit, 1 file changed)
- [CurlFile] proper setup proxy credentials (PR:17711, 1 commit, 1 file changed)
- [depends] bump libzip to 1.6.1 (PR:17706, 2 commits, 2 files changed)
- Don't unnecessarily update setting controls (PR:17093, 7 commits, 5 files changed)
- [GBM] CVideoBufferDMA: add class to use CBufferObject (PR:17688, 2 commits, 8 files changed)
- [Android] Ignore intents until application is initialized (PR:17714, 1 commit, 1 file changed)
- pvr.iptvsimple:
- Add all inputstreams as dependencies and fix debian control file (PR:361, 1 commit, 3 files changed)
- pvr.zattoo:
- Add French categories (PR:86, 1 commit, 1 file changed)
- Updated: [env] PR:4291 (perma): linux (Generic/Allwinner): update to linux-5.6.6
- Added: [env] PR:4340 (perma): libzip: update to libzip-1.6.1
- Added: [env] PR:4341 (perma): dbus, systemd: fix duplicate tmpfiles and missing groups
- Updated: [pkg] PR:17713 (perma): [VP] Postpone DMX_SPECIALID_STREAMCHANGE until player is started
- Added: [pkg] PR:17718 (perma): Fix crash on exit.
- Added: [pkg] PR:17720 (perma): [settings] don't load setting values twice
- Reverted: [pkg] PR:17458: Add error handling code for some external APIs (reason: crashes on startup)
Hello.
First of all, huge thanks for all of the work you do with these builds. I regularly use these but sadly don't contribute as much as I would like but since I only use my KODI in a much simpler way than others then usually there's little I can add. However, there is one pretty major issue (to me) which I have recently seen crop up in some other discussions that I hope you can help with.
When using full DVD images (whether ISO or folder)
movement between menus has 'stuck' if the movement is from a menu screen with a video playing in the background to a static screen. The menu is still there but the screen does not update to show it. Therefore pressing enter will start to play the feature or episode. This issue is much more prevalent in TV series where the menu option selected is to move to an episode select screen for example, Dr Who DVDs.
However This issue
ONLY happens when
'Allow MPEG2 hardware acceleration-VAAPI' is set to
ON in the main player settings menu. With this turned off then the menu operates as usual but then the use of anything like Lanczos3 reults in choppy playback (on my NUC6CAYH especially). Which is a shame as it runs really well with it enabled otherwise.
i have read that it may be an issue that when entering such screens that the menu is set with a
framerate of 0. If this helps at all.
I really hope I've managed to shed any light on this issue if it is affecting anyone other than me
but i do have a large collection of 100s of isos I have transferred from my disc collection so It would be difficult to rerip every one in a different format.
Many many thanks for your time. I hope anything above is of use.
(2020-04-19, 23:06)sixpack58 Wrote: [ -> ]a) that after the first stick-Install the "boot mimik" remains . It's what the USB-creator puts on the stick (all modes: install (default selected), run, live, ...) ....
I told bullshit, sorry !
"boot mimik" shifts to run mode after stick install
(2020-04-22, 22:18)sixpack58 Wrote: [ -> ] (2020-04-19, 23:06)sixpack58 Wrote: [ -> ]a) that after the first stick-Install the "boot mimik" remains . It's what the USB-creator puts on the stick (all modes: install (default selected), run, live, ...) ....
I don't know what "boot mimik" is but the boot menu "remembers" the last boot mode - a freshly imaged memory stick defaults to
installer
mode - so if you boot into
run
mode then the memory stick will continue automatically booting into
run
mode until another boot mode is entered.
(2020-04-22, 23:58)Milhouse Wrote: [ -> ] (2020-04-22, 22:18)sixpack58 Wrote: [ -> ] (2020-04-19, 23:06)sixpack58 Wrote: [ -> ]a) that after the first stick-Install the "boot mimik" remains . It's what the USB-creator puts on the stick (all modes: install (default selected), run, live, ...) ....
I don't know what "boot mimik" is but the boot menu "remembers" the last boot mode - a freshly imaged memory stick defaults to installer
mode - so if you boot into run
mode then the memory stick will continue automatically booting into run
yup, got it already ...
"boot
mimik mimic" := boot into boot manger => select a mode => wait for the timer count down => boot the selected mode (and set that mode for next boot)
anyway, I was wrong in my comment #903
and had the feel to correct that.
that's all
New LibreELEC.tv Matrix build #0422:
Generic
SHA256 Checksum:
681270d77913712050c12e89617e071f492aab2210e1fa18f1ea14cbe9578b1a
(Generic)
text:
# uname -a
Linux NUC 5.6.6 #1 SMP Thu Apr 23 00:36:35 BST 2020 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20200423003532-#0422-gd4d6cc7 [Build #0422]
# Kodi version
Starting Kodi (19.0-ALPHA1 Git:cdb887b). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (d4d6cc7,
XBMC master (cdb887b,
- Include [env] PR:4345 (perma): mesa: update to mesa-20.0.5
- Include [pkg] patch: Fix CRTC+planes selection (kodi)
- Include [pkg] PR:17652 (perma): [Filesystem] HTTP Directory parser enhancements for multi-line anchor tags
Build Highlights:
- mesa: update to mesa-20.0.5
- kodi: Fix crash on startup (broken by PR17458)
- kodi: [Filesystem] HTTP Directory parser enhancements for multi-line anchor tags
Build Details:
- LibreELEC.tv:
- librespot: handle non ascii track information (PR:4342, 1 commit, 3 files changed)
- emby4: update to 4.4.2.0 (PR:4335, 6 commits, 9 files changed)
- kodi binary addons: add vfs.sacd and missing visualization addons (PR:4337, 5 commits, 5 files changed)
- XBMC:
- [packaging iOS/tvOS] fix wrong architecture field in deb control file (PR:17707, 1 commit, 1 file changed)
- [docs] tvOS updates (PR:17728, 1 commit, 2 files changed)
- Fix startup issue linux (PR:17731, 2 commits, 1 file changed)
- [docs][python] Improve documentation for xbmc.sleep and xbmc.Monitor( (PR:17732, 1 commit, 2 files changed)
- Added: [env] PR:4345 (perma): mesa: update to mesa-20.0.5
- Added: [pkg] patch: Fix CRTC+planes selection (kodi)
- Updated: [pkg] PR:420 (perma): Matrix API change to v2.2.0 - Allows upto 256 streams, useful for netflix etc. (inputstream.adaptive)
- Updated: [pkg] PR:17718 (perma): Fix crash on exit.
- Added: [pkg] PR:17652 (perma): [Filesystem] HTTP Directory parser enhancements for multi-line anchor tags
Ok, a bit of a update, love to be able to send the log file from the system but it will not send, it times out. Will do a bit of more investigation to see if my network is stopping connection to IX.IO web site.
Now the installation does work, but only if I do a fresh install and do no changes to the base install before adding your release. I can also do a proper update if I do a installation reset to fresh install state. This was never a problem before as I have setup many boxes where I have setup profiles and added addons before updating to your releases the last one I did was back around release #0301. If I get bored again this weekend I will play around installing and updating till I find the error point.
Now back to the problem that started all this, all is good until I add a profile or even tell the system to boot to profile page select page. I can enter a profile it works fine log out of profile and try to enter a new profile or even go back to the same profile instant hard lock reset button only option.
log-2020-04-22-07.22.17 As before the only way I can post a log till I figure out what is stopping the upload to IX.IO
@TVmine: Nothing obvious relating to profiles in you kodi logs. Just a suggestion, but it might be a good idea to run
Memtest86+ on your machine to rule out any hardware issues that may be causing such weird behaviour.
I was testing latest version #424 on my RPi2 with Libereelec to see if I can get Netflix working better.
I only use it at 720p (sorry I set that after the log, but same result anyway) on an old TV so am not asking for miracles.
However while shows play Ok if you (i) do not pause them or (ii) try to go forward by time <enter> or (iii) try to skip recap - if you try that they stop.
I am using the Matrix version of Netflix Add-on from
https://github.com/CastagnaIT/plugin.video.netflix.
(by the way the Section 6 in the first post referring to
https://github.com/kodinerds/repo/tree/m...ry.netflix throws an error on that page).
I have not tried the daily build.
I had problems with logfile uploader like the fellow above, apologies. It should be here though, apologies in advance for that.
http://www.filedropper.com/kodi
When I start the show I see an Error on screen that the netflix "streamcontinuitymanager" has been disabled.
It is definitely repeatable. I do not see this error in the log however?
Any help would be appreciated. Even just for someone to say the RPi2 is a bit low on processing power for what I am trying to do... even at 720p.
Cheers
k.
