(2019-06-04, 02:54)asavah Wrote: [ -> ]@SirMacke It's a known kernel bug.
https://bugzilla.kernel.org/show_bug.cgi?id=203643
it also affects some bluetooth headsets.
@Milhouse
If you want to fix this in your builds there are 2 ways to tackle this
1) revert https://github.com/torvalds/linux/commit...c0ea458265
or
2) apply this (not merged upstream yet) patch https://lore.kernel.org/linux-bluetooth/...n.org/T/#u
The latter reportedly fixed the issue with sixaxis but fails to fix the issue with headsets, the safest way atm IMO is the revert.
asavah Thanks, but the commit you suggest reverting first appeared in 5.1.1 and isn't in 5.0.y until 5.0.15 (the last 5.0.y kernel for these builds is 5.0.13) but the problem being reported by @
SirMacke is apparently with 5.0.10 (#0427). Unfortunately it's a vague confirmation so I can't be sure as he's not sure, and I don't have the time to look into vague reports.
If the bad build number is confirmed/certain then sure, I can spend some time trawling through whatever changed.
@SirMackie all you need to do is test #0426 and #0427 - if you confirm #0426 works and #0427 does not then that's something for me/others to go on, but unfortunately if you're not sure of the build numbers I don't have the time for a potentially wild goose chase.
(2019-06-03, 13:55)lusephur Wrote: [ -> ]Just updated from may 19th daily to June 2nd. My external usb drive formatted to exfat is not recognised. (the other drives formatted to fat32,ntfs,ext4 are.) Exfat drive has been checked with chkdsk and gives no errors, is recognised on other machines (antiquated windows machine and a more recent laptop running manjaro with linux 5.0.20.
Reflashing back to may 19th and drive is again recognisable.
Currently in the midst of moving, have no time to check where the regression occurred. Hopefully it's a simple fix.
I appreciate you're in the middle of a move but testing #0529 and #0530 and confirming which is working/not working would help - I bumped the version of
fuse
and
fuse-exfat
in #0530.
If both are working (or not working) then I'll need you to pin down the breaking build by testing the builds between #0519 and #0602 - I don't have exfat drives to test with.
With a broken build (ideally #0603) please connect your exfat drive and then run
journalctl -a | pastebinit
and post the link so I can see what error is being reported (if any).
New LibreELEC.tv Matrix build #0604:
Generic
(Supercedes previous build)
SHA256 Checksum:
c676bf3bb2f84ae7c1ba7a0d2883a1b08a9a01b9c2f307ee97922d6e8e13cfb1
(Generic)
text:
# uname -a
Linux NUC 5.1.7 #1 SMP Tue Jun 4 21:16:04 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190604211523-#0604-g5d2f206 [Build #0604]
# Kodi version
Kodi (19.0-ALPHA1 Git:75c1d6b). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (5d2f206,
changelog) and tip of
XBMC master (75c1d6b,
- Includes latest kodi-platform master (915da08, ahead +1)
- Includes latest libcec master (ba9b538, ahead +1)
- Includes latest libnfs master (ca939ba, ahead +3)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (a88ac07, +21), inputstream.rtmp (ce68b77, +1), peripheral.joystick (910bd3d, +8), peripheral.xarcade (d218f0d, +6), pvr.argustv (dec20f6, +5), pvr.demo (f545831, +7), pvr.dvblink (a960e89, +5), pvr.dvbviewer (324db50, +7), pvr.filmon (5265b91, +5), pvr.hdhomerun (ebeb5dc, +5), pvr.hts (773ff1b, +5), pvr.iptvsimple (ee94b98, +6), pvr.mediaportal.tvserver (63de57a, +8), pvr.mythtv (56176ab, +8), pvr.nextpvr (e72e429, +5), pvr.njoy (fe6d356, +8), pvr.octonet (69da8db, +7), pvr.pctv (af86814, +5), pvr.stalker (f926a51, +6), pvr.teleboy (926d584, +4), pvr.vbox (70732cc, +5), pvr.vdr.vnsi (1defc99, +5), pvr.vuplus (da427a8, +23), pvr.waipu (81f5543, +8), pvr.wmc (38de15a, +5), pvr.zattoo (e794e5a, +7), vfs.libarchive (2ba1102), vfs.rar (e6b5114, +1), vfs.sftp (3ab3969, +3)
- Include [env] compare (perma): kodi19: next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3522 (perma): bcm2835-bootloader: cleanup update.sh
- Include [env] PR:3523 (perma): cleanup initramfs build, drop support for kernel modules in initramfs
- Include [env] PR:3524 (perma): buildsystem: add "speed" flag for package building
- Include [env] PR:3527 (perma): glibc: raise minimum kernel supported to 4.4.0
- Include [env] PR:3528 (perma): linux: drop ati_remote.conf modprobe file
- Include [env] PR:3531 (perma): buildsystem: cleanup (addons) and fix (linux)
- Include [env] PR:3534 (perma): amremote/atvclient: cleanup
- Include [env] PR:3537 (perma): packages: mega bump
- Include [env] PR:3539 (perma): cleanup: Remove code related to kernels 3.14 and 3.10 on WiFi drivers.
- Include [env] PR:3540 (perma): linux (RPi/Generic/Allwinner): update to linux-5.1.7
- Include [env] PR:3542 (perma): dvb-update
- Include [env] PR:3543 (perma): xf86-video-nvidia: update to xf86-video-nvidia-430.14
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:130 (perma): make Estuary elements conditional (service.libreelec.settings)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:14908 (perma): [addons] remove cpluff
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15680 (perma): Clear focus-history when leaving window with focus on parent folder item (Fixes #15608)
- Include [pkg] PR:15771 (perma): RetroPlayer: Move rendering calls to initialize/deinitialize methods
- Include [pkg] PR:15831 (perma): [libUPnP] Remove unused headers from Platinum/Source/Extras
- Include [pkg] PR:16216 (perma): resolution whitelist version 2
Build Highlights:
- New 5.1.7 kernel
- xf86-video-nvidia: update to xf86-video-nvidia-430.14
Build Details:
- XBMC:
- support AVCHD format disk/image/folder (PR:16131, 1 commit, 3 files changed)
- Updated: [env] PR:3540 (perma): linux (RPi/Generic/Allwinner): update to linux-5.1.7
- Added: [env] PR:3543 (perma): xf86-video-nvidia: update to xf86-video-nvidia-430.14
(2019-06-04, 17:27)Milhouse Wrote: [ -> ]@asavah Thanks, but the commit you suggest reverting first appeared in 5.1.1 and isn't in 5.0.y until 5.0.15 (the last 5.0.y kernel for these builds is 5.0.13) but the problem being reported by @SirMacke is apparently with 5.0.10 (#0427). Unfortunately it's a vague confirmation so I can't be sure as he's not sure, and I don't have the time to look into vague reports.
This
RPi post suggests that Bluetooth issues were first seen in #0514 which - in the case of RPi - corresponds with the introduction of kernel 5.1.1 (updating from 5.1.0). This is why I'm a bit anal about bug reports being accurate rather than vague with regard to working/not working build numbers!
In kernel 5.1.1 there are four new Bluetooth related commits:
https://github.com/torvalds/linux/commit...228e50cce7
https://github.com/torvalds/linux/commit...0c11a503a1
https://github.com/torvalds/linux/commit...4522ae806b (as suggested by @asavah)
https://github.com/torvalds/linux/commit...b44ec4d3d3
For x86_64 we switched to 5.1.1 with
#0512.
SirMacke it would be worth testing #0511 and #0512, and confirming if the same Bluetooth working/not working behaviour is seen there.
I'll upload a build later this evening with the commit suggested by @
asavah reverted.
Weekly Linux 5.2-rc3 build #0604x:
Generic
Known issues:
text:
No dvb-latest or crazycat drivers
Temporary bluez build hack
(2019-06-03, 15:38)SirMacke Wrote: [ -> ]Issue since #0427 I think.
Using a Playstation 3 Bluetooth remote to my Intel NUC running LibreElec + Kodi native.
From #0427 (I guess, did not check version before upgrade) I can no longer connect the remote.
It has always been connected automatically before, but now it is disconnected.
It cannot be paired any more.
"Pair, connect" only gives a Bluetooth Input/Output error.
Backing to a version before this and the remote works again.
Tried the onboard Bluetooth and an old DLink USB-dongle. Same issue.
Log:
http://ix.io/1KOr
SirMacke can you test build #0604b:
Generic - it has this
BT kernel commit reverted.
(2019-06-04, 23:00)Milhouse Wrote: [ -> ] (2019-06-04, 17:27)Milhouse Wrote: [ -> ]@asavah Thanks, but the commit you suggest reverting first appeared in 5.1.1 and isn't in 5.0.y until 5.0.15 (the last 5.0.y kernel for these builds is 5.0.13) but the problem being reported by @SirMacke is apparently with 5.0.10 (#0427). Unfortunately it's a vague confirmation so I can't be sure as he's not sure, and I don't have the time to look into vague reports.
This RPi post suggests that Bluetooth issues were first seen in #0514 which - in the case of RPi - corresponds with the introduction of kernel 5.1.1 (updating from 5.1.0). This is why I'm a bit anal about bug reports being accurate rather than vague with regard to working/not working build numbers!
For x86_64 we switched to 5.1.1 with #0512.
@SirMacke it would be worth testing #0511 and #0512, and confirming if the same Bluetooth working/not working behaviour is seen there.
I'll upload a build later this evening with the commit suggested by @asavah reverted.
Hello, yes I just tested every kernel upgrade from 0426 and indeed the issue appears in #0512 and working fine in #0511
Just did an update to #0604 after not updating for ~ 3 weeks in the milhouse 9.1 and I note that my exfat external USB drives are now not mounting. I have rolled back to #0504 (not sure exactly what version I was on before hand. But exfat is now working again, and I will test and find the release that it broke in.
I can confirm after testing that #0529 works with exfat. And #0530, #0531 and #0604 do not work with exfat.
(2019-06-05, 14:39)Fourweddings Wrote: [ -> ]Just did an update to #0604 after not updating for ~ 3 weeks in the milhouse 9.1 and I note that my exfat external USB drives are now not mounting. I have rolled back to #0504 (not sure exactly what version I was on before hand. But exfat is now working again, and I will test and find the release that it broke in.
Thanks, that gives me something to work on. A journalctl as requested would have been nice.
(2019-06-05, 12:01)SirMacke Wrote: [ -> ]Hello, yes I just tested every kernel upgrade from 0426 and indeed the issue appears in #0512 and working fine in #0511
OK same issue reported by the RPi user. Thanks.
(2019-06-04, 17:36)Milhouse Wrote: [ -> ] (2019-06-03, 13:55)lusephur Wrote: [ -> ]Just updated from may 19th daily to June 2nd. My external usb drive formatted to exfat is not recognised. (the other drives formatted to fat32,ntfs,ext4 are.) Exfat drive has been checked with chkdsk and gives no errors, is recognised on other machines (antiquated windows machine and a more recent laptop running manjaro with linux 5.0.20.
I appreciate you're in the middle of a move but testing #0529 and #0530 and confirming which is working/not working would help - I bumped the version of fuse
and fuse-exfat
in #0530.
With a broken build (ideally #0603) please connect your exfat drive and then run journalctl -a | pastebinit
Sorry for the delay in replying. Unfortunately, I can't test any versions as everything is packed up at present. It'll be a week or so before I can get access. Sorry.
(2019-06-05, 17:14)lusephur Wrote: [ -> ]Sorry for the delay in replying. Unfortunately, I can't test any versions as everything is packed up at present. It'll be a week or so before I can get access. Sorry.
OK thanks - I'm working on reproducing it. Seems to be a compatibility issue between libfuse and the latest fuse-exfat.
I'll be downgrading fuse-exfat
from 1.3.0 to 1.2.8 (there wasn't a 1.2.9) as fuse-exfat-1.3.0
seems to have compatibility issues with libfuse-2.9.9
- fuse-exfat-1.3.0
includes changes in preparation for libfuse-3.x
which don't appear to be backwardly compatible with libfuse-2.x
And no, we can't yet upgrade to libfuse-3.x
as fuse-exfat-1.3.0
doesn't actually build with libfuse-3.x
! So, best to avoid fuse-exfat-1.3.0
for now until it fully aligns with libfuse-3.x
New LibreELEC.tv Matrix build #0605:
Generic
SHA256 Checksum:
57982c16e4235ea5a731661cbfdc5851a128491edef9337c396f58fdb0d9c8de
(Generic)
text:
# uname -a
Linux NUC 5.1.7 #1 SMP Wed Jun 5 21:22:17 BST 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190605212134-#0605-g17cda55 [Build #0605]
# Kodi version
Based on tip of
LibreELEC.tv master (17cda55,
Build Highlights:
- Downgrade
fuse-exfat
to 1.2.8 due to mounting issues (thanks @KrX3D, @Fourweddings)
- Revert kernel Bluetooth commit to fix PS3 pairing issues (thanks @asavah, @SirMacke)
Build Details:
- LibreELEC.tv:
- buildsystem: cleanup (addons) and fix (linux) (PR:3531, 14 commits, 19 files changed)
- linux: drop ati_remote.conf modprobe file (PR:3528, 1 commit, 1 file changed)
- cleanup initramfs build, drop support for kernel modules in initramfs (PR:3523, 10 commits, 13 files changed)
- Updated: [env] PR:3537 (perma): packages: mega bump
(2019-06-05, 22:00)Milhouse Wrote: [ -> ]I'll be downgrading fuse-exfat
- fuse-exfat-1.3.0
as fuse-exfat-1.3.0
Hi @
Milhouse, I can confirm #0605 is good for exfat now.
