Full Version: Changes to the skinning engine for Kodi Matrix
Pages: 1 2 3 4
2020-09-20 changed infolabels
the following Player info labels now support offset() and position()
  • Player.Title
  • Player.Folderpath
  • Player.FilenameAndPath
  • Player.Filename
this allows you to display info for the next items in a playlist during playback.
examples:
xml:
Player.offset(1).Title
Player.position(3).Filename
pull-request: https://github.com/xbmc/xbmc/pull/18410
commit: https://github.com/xbmc/xbmc/commit/bd9f...338c56866a
2020-10-14 new infolabel
  • PVR.TimeShiftSeekbar
this is the equivalent of Player.Seekbar, but for LiveTV.
this infolabel can be used in a slider control and indicates the position being seeked to.
pull-request: https://github.com/xbmc/xbmc/pull/18541
commit: https://github.com/xbmc/xbmc/commit/950b...ee82daddb8
not a change in kodi, but for skins that ship with a custom script-cu-lrclyrics-main.xml file,
please remove control id="120" (and all references to it) as the cu lrc lyrics addon no longer uses it.
this control was used to display a list of available lyrics for a song, the addon will now use kodi's select dialog for this.
2020-09-09 removed infobool
  • System.Platform.Linux.RaspberryPi
this platform specific boolean condition has been removed.
you can use System.Platform.Linux instead to detect linux based systems (including the raspberry pi).
pull-request: https://github.com/xbmc/xbmc/pull/16321
commit: https://github.com/xbmc/xbmc/commit/811b...4980183b54
  • System.AddonUpdateCount
the number of available addon updates.
pull-request: https://github.com/xbmc/xbmc/pull/18546
commit: https://github.com/xbmc/xbmc/commit/e046...126425f8a5
2020-10-14 DialogAddonInfo.xml - new button
please add a button with id="14" (label: 24069) to the addon info dialog.
Pages: 1 2 3 4
