Full Version: TVheadend and pvr.hts addon inconsistency
Kodi 18.1, pvr.hts addon 4.4.16, Tvheadend 4.2.8-23~g74cdf3f16
I have the following settings in Tvheadend for recording:
Format string: $c/$t$n.$x
Make subdirectories per day: unchecked
Make subdirectories per channel: checked
Make subdirectories per title: unchecked
So as to create directories and files as follows:
/Data/Recordings/BBC ONE/Casualty.mkv
/Data/Recordings/BBC ONE/Casualty-1.mkv
/Data/Recordings/Channel 4/New: Joe Lycett's Got Your Back.mkv
/Data/Recordings/Channel 4/New: Joe Lycett's Got Your Back-1.mkv
..etc.
When setting a recurring timer in Kodi, however, the pvr.hts addon insists on populating an edit box with the name of the program, thereby making a subdirectory per title, which is not what I require.
Should the settings in Tvheadend take priority, or those in the pvr.hts addon?
(2019-04-17, 00:23)dnairb Wrote: [ -> ]Kodi 18.1, pvr.hts addon 4.4.16, Tvheadend 4.2.8-23~g74cdf3f16
..etc.
You could just leave the directory edit field in the Kodi timer settings dialog empty.
Unfortunately, there is no way for the addon to access the respective tvh settings.
(2019-04-17, 07:49)ksooo Wrote: [ -> ]Unfortunately, there is no way for the addon to access the respective tvh settings.
That is unfortunate. Oh well, never mind. Thank you for your reply.
