Full Version: Video info when video is paused
Hi, can you guys guid me if I can change my displayseekbar.xml to include the video info so every time I pause a video I have the information
Thank you
(also totally another subject but wich font size I need to change to make it a bit bigger in video list menu ? )
Try adding this just after the <window> tag on line 2:
PHP Code:
    <onload condition="!Player.ShowInfo + Player.Paused">Info</onload>
onunload condition="Player.ShowInfo">Info</onunload
(2019-04-17, 11:39)nonJon Wrote: [ -> ]Try adding this just after the <window> tag on line 2:
PHP Code:
I had to had this in my dysplayseekbar ? if so it doesn't work ... thanks for your help ...
EDIT: IT WORK THANK YOU !! but it won't go away after I hit play again .... Did you have a tips for that ?
That is a problem with pellucid @thedeadman would need to address.
