2019-04-19, 23:33
Since updating to Kodi 18 I haven't been able to find the setting to use limited color range. Has this option been moved or deleted, or am I just not seeing it?
(2019-04-20, 12:06)Memphiz Wrote: [ -> ]It’s still under settings - system - video - ensure to set settings to expert level to see them all.I have expert settings enabled. Under system I don't have Video as an option, did you mean Display? I have Video as an option under Player but there is no option for limited color under either.
(2019-04-21, 19:56)Memphiz Wrote: [ -> ]you are Right - it vanished on macOS for some reasons I am trying to figure out ...If you need someone to test a build or anything, I'm happy to help.
limited range in Kodi is actually a hack that is not possible by design of gl, video drivers, and TVs. GL is full range by design and has no means to pass through limited range. That means if video driver is configured for limited range, it will convert GL's full range to limited range and lose head/foot room. If video driver is configured for full range RGB and works properly, it will send an info frame and the TV configures for full range too.
Limited range works on Linux with Intel drivers if TV ignores info frame.
