2019-07-05, 14:41
2019-07-05, 14:41
2019-07-07, 18:23
18.8-61, 7 July 2019: Based off OSMC commit (ad1bf516e) and newclock5 (37bde6ae5)
XBMC:
XBMC:
- [cmake] Use CORE_PLATFORM_NAME, not PLATFORM (PR:16346, 1 commit, 1 file changed)
- reformat pointers, statement brackets and arithmetic spacing as per coding guidelines (5ce52fd)
- [VideoPlayer] Load program from stream property without using streaminfo (e68bc9f)
- [VideoPlayer] Load program from stream property without using (#16314) (97fe0eb)
2019-07-08, 18:47
2019-07-14, 08:49
18.8-63, 14 July 2019: Based off OSMC commit (e64a3cf9) and newclock5 (ab485a75)
OSMC:
XBMC:
newclock5:
Updated commits in this build:
OSMC:
- Revert RPProcessInfo: drop method ConfigureRenderSystem
- Revert fixup Order
XBMC:
- [PVR][Estuary] Generate thumbnail picture for channel groups. (PR:16360, 1 commit, 12 files changed)
- [PVR] Group manager: Automatically fill channel lists upon group selection. (PR:16361, 2 commits, 2 files changed)
- Remove ARB postfix from GL functions (PR:14571, 3 commits, 7 files changed)
- Fix PAPlayer to do passthrough for TrueHD (PR:16336, 1 commit, 1 file changed)
- [format] fix include order (PR:16325, 6 commits, 1911 files changed)
newclock5:
- Revert "VideoPlayerVideo: Invert stereo flags from codec when option is enabled" (169bc15d => 4a4636fa)
2019-07-19, 13:57
18.8-64, 19 July 2019: Based off OSMC commit (dbf2d0a4f2) and newclock5 (ab485a75)
XBMC:
XBMC:
- [PVR] Refactor and fix channel paths (PR:16368, 4 commits, 25 files changed)
- changed: Delete stream details when video info is refreshed (PR:16342, 1 commit, 3 files changed)
2019-07-22, 18:40
18.8-66, 22 July 2019: Based off OSMC commit (436395df14) and newclock5 (ab485a75)
XBMC:
XBMC:
- VideoPlayer: Properly propagate playback errors (PR:16369, 1 commit, 2 files changed)
2019-07-25, 19:28
18.8-67, 25 July 2019: Based off OSMC commit (33b8b15c8) and newclock5 (6058a8ff)
XBMC:
XBMC:
- Clear focus-history when leaving window with focus on parent folder item (Fixes #15608) (PR:15680, 2 commits, 1 file changed)
- [PVR] Fix CPVRChannelGroupInternal ctor - fixes #16386. (PR:16392, 2 commits, 4 files changed)
- [PVR] Add progress bar to reminders announcement dialog (PR:16393, 2 commits, 4 files changed)
2019-08-01, 17:20
18.8-68, 1 Aug 2019: Based off OSMC commit (4ff6a2cf) and newclock5 (6058a8ff)
XBMC:
p8-platform:
XBMC:
- [ESTUARY] Fix radio button text length (PR:16407, 1 commit, 1 file changed)
- [PlaylistPlayer] Do not attempt to further resolve plugin paths for failing entries (PR:16405, 1 commit, 1 file changed)
- [GUI] Fix season/episode formatting for video addons (PR:16380, 1 commit, 1 file changed)
- [p8-platform] Update p8-platform sha for PR5 (PR:16417, 1 commit, 1 file changed)
p8-platform:
- Fixes to make addons build after the unicode switch (PR:1, 2 commits, 9 files changed)
- [windows] atomics: replace inline assembler with intrinsics (PR:2, 1 commit, 1 file changed)
- PR 16039 platform darwin_embedded (PR:5, 1 commit, 2 files changed)
- Fix PlayMedia builtin for smart playlists and playlists (PR:16327, 1 commit, 1 file changed)
2019-08-03, 22:14
2019-08-05, 19:17
18.8-70, 3 Aug 2019: Based off OSMC commit (e302c0bc) and newclock5 (6058a8ff)
XBMC:
XBMC:
- Fix CShoutcastFile's ability to set the stream's tag info on the UI (PR:16435, 2 commits, 1 file changed)
- [GUIControllerWindow] Subscribe to controller install events (PR:16424, 2 commits, 2 files changed)
- add ACTION_MOUSE_DRAG_END support (PR:16384, 1 commit, 3 files changed)
- [addons] fix binary addon lib name for iOS (PR:16411, 1 commit, 1 file changed)
- [addons] Remove unneded dlfcn includes (PR:16423, 1 commit, 1 file changed)
2019-08-08, 19:21
2019-08-10, 18:34
18.8-72, 10 Aug 2019: Based off OSMC commit (0454ecb33) and newclock5 (6058a8ff)
XBMC:
pvr.dvblink:
pvr.freebox:
pvr.hts:
pvr.mediaportal.tvserver:
pvr.mythtv:
pvr.nextpvr:
pvr.octonet:
pvr.teleboy:
pvr.vbox:
pvr.vdr.vnsi:
pvr.wmc:
pvr.zattoo:
XBMC:
- [addons] change ADDON_GLOBAL_VERSION_MAIN to 1.1.0 and leave min by old 1.0.12 (PR:16455, 2 commits, 4 files changed)
- Fix typo in CDVD*CodecFFmpeg cryptosession log messages (PR:16457, 1 commit, 2 files changed)
- [Cleanup] Remove SetIconImage, GetIconImage, HasIcon and SetThumbnailImage (NOP) (PR:16444, 5 commits, 47 files changed)
- [dialogs] Fix missing cancel button in progress dialogs. Fixes #16459 (PR:16460, 1 commit, 1 file changed)
pvr.dvblink:
- [pvr.dvblink] 5.1.0 (PR:122, 1 commit, 2 files changed)
pvr.freebox:
- [pvr.freebox] 2.1.0 (PR:17, 1 commit, 1 file changed)
pvr.hts:
- [pvr.hts] bump to 5.1.0 (PR:423, 1 commit, 2 files changed)
- [pvr.mediaportal.tvserver] Update to 4.1.0 (PR:105, 1 commit, 2 files changed)
pvr.mythtv:
- [pvr.mythtv] bump to 6.1.0 (PR:123, 1 commit, 2 files changed)
pvr.nextpvr:
- [pvr.nextpvr] bump to 4.1.0 (PR:96, 1 commit, 2 files changed)
pvr.octonet:
- [pvr.octonet] 1.1.0 (PR:29, 1 commit, 1 file changed)
pvr.teleboy:
- [pvr.teleboy] bump to 19.1.0 (PR:20, 1 commit, 2 files changed)
pvr.vbox:
- [pvr.vbox] bump to 5.1.0 (PR:220, 1 commit, 2 files changed)
pvr.vdr.vnsi:
- [pvr.vdr.vnsi] bump to 4.1.0 (PR:119, 1 commit, 2 files changed)
pvr.wmc:
- [pvr.wmc] 3.1.0 (PR:70, 1 commit, 2 files changed)
pvr.zattoo:
- [pvr.zattoo] bump to 19.1.0 (PR:53, 1 commit, 2 files changed)
2019-08-11, 18:30
2019-08-13, 14:08
2019-08-15, 19:11
18.8-75, 15 Aug 2019: Based off OSMC commit (ea6f879ea) and newclock5 (6058a8ff)
XBMC:
pvr.iptvsimple:
XBMC:
- [cmake] add support for install bigger addon dir structure (PR:16406, 3 commits, 6 files changed)
- [settings/cosmetic] Replace "computer" by "device" in setting help text (PR:16487, 1 commit, 1 file changed)
- FFmpeg: Bump to 4.0.4-Leia-18.4 (PR:16461, 1 commit, 1 file changed)
- [doxygen] update and sync addon doxyfile to main doxyfile (PR:16482, 1 commit, 1 file changed)
pvr.iptvsimple:
- Extvlcopt support matrix (PR:244, 9 commits, 8 files changed)
