2019-04-21, 06:56
With Kodi Leia now branched, the master is on Matrix (v19)
Previous Leia nightlies can be found here.
OSMC Test Builds for Kodi 19 for Raspberry Pi 1 & 2/3
Based on the Kodi master Leia (v19) and popcornmix's newclock
Warning
Kodi 19 is currently in Alpha and there is likely to be a lot of activity in the coming months. As these are alpha builds expect some issues.
Before proceeding make sure you have a backup of your Raspberry Pi. As these are test builds there could well be some unexpected problems.
Database upgrades could also be an issue. Please make a backup of the Kodi database before installing, especially if you are running a remote MySQL database.
Installing
You need a working system in order to install these test builds. If you do not have OSMC already installed then go to https://osmc.tv/download/ to install the latest stable version.
First step is to point to gmc-19. If you were running v18 nightly builds then you are probably already have this configured.
Edit
Save and exit file.
Import gpg certificate:
Finally run update and dist-upgrade to install latest nightly.
And then issue the following command to install a test build for Raspberry Pi 2 or 3:
To install a Raspberry Pi 1 or Raspberry Pi Zero build, issue the following command:
You can now update to the latest build when it is published with the following commands:
Support:
Since we are in alpha there could be a lot of incompatibilities with skins and addons. To resolve these its best taking the issue up with the addon developer.
If you have any issues with OSMC please provide debug logs. Most problems are almost impossible to fix if we don't have the debug logs.
How to submit a useful support request
Archive:
http://kodi.gjmccarthy.co.uk
To confirm which version you are running:
Current Build
Previous Builds
Warning
Installing
Edit
/etc/apt/sources.list
deb http://download.osmc.tv/dev/gmc-19/public gmc-19 main
Save and exit file.
wget -qO - http://download.osmc.tv/dev/gmc-19/public/pubkey.asc | sudo apt-key add -
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install rbp2-mediacenter-osmc
sudo apt-get install rbp1-mediacenter-osmc
sudo apt-get update
Support:
Quote:https://osmc.tv/wiki/general/how-to-subm...t-request/
Archive:
dpkg -l | grep mediacenter-osmc | awk '{ print $3 }'
Current Build
- 18.8-105, 18 Nov 2019
Previous Builds
- 18.8-104, 13 Nov 2019
- 18.8-103, 11 Nov 2019
- 18.8-102, 10 Nov 2019
- 18.8-101, 4 Nov 2019
- 18.8-100, 29 Oct 2019
- 18.8-99, 13 Oct 2019
- 18.8-98, 12 Oct 2019
- 18.8-97, 11 Oct 2019
- 18.8-96, 10 Oct 2019
- 18.8-95, 7 Oct 2019
- 18.8-94, 6 Oct 2019
- 18.8-93, 4 Oct 2019
- 18.8-92, 3 Oct 2019
- 18.8-91, 29 Sep 2019
- 18.8-90, 28 Sep 2019
- 18.8-89, 27 Sep 2019
- 18.8-88, 23 Sep 2019
- 18.8-87, 22 Sep 2019
- 18.8-86, 20 Sep 2019
- 18.8-85, 19 Sep 2019
- 18.8-84, 18 Sep 2019
- 18.8-83, 6 Sep 2019
- 18.8-82, 4 Sep 2019
