Full Version: Some movies not recognized with TheMovieDB Scraper
Hi there,
since a couple of days I've some problems with scraping some movies.
At all 95% are working well, but some aren't still recognized, for example (at the moment) Titan A.E.
I've named directory and movie file "Titan A.E. (2000).mkv" but still not recognized.
My log entry is:
Quote:16:34:05.550 T:5600 WARNING: No information found for item 'smb://nas/public/Multimedia/Archiv/Titan A.E. (2000)/Titan A.E. (2000).mkv', it won't be added to the library.
I'm wondering also, that I can't manually search for the movie?
In my mind in old Kodi versions it was possible to search for the movie title? I'm using Estuary Skin
Thanks for your help :-)
We need the full Debug Log
OK, I uploaded a debug log to -> Link
The scraping for Titan A.E. begins from line 1090.
And there is also a movie "Prodigy" which is not recognized (Line 1317)
I think the problem is item 1d here... https://forum.kodi.tv/showthread.php?tid=336969
If that is not it, then can you enable the setting Movies are in separate folders that match the movie title in the Set Content screen... https://kodi.wiki/view/Adding_video_sources#Set_Content
Thank you so much for the hint.
With disabling VideoTag-Option it is now recognizing the movies :-)
Great!!
Thread marked solved.
Hello , i ' ve same problem , but i'm french can you translate " VideoTag-Option " in french svp ?
it is this : utiliser les balises video ?
(2019-04-23, 20:33)iznobe Wrote: [ -> ]but i'm french can you translate " VideoTag-Option " in french svp ?
I'll do one better, I will show you where it is.
Section 1.2... https://kodi.wiki/view/Settings/Media/Videos#All
Disable it
(2019-04-23, 22:59)Karellen Wrote: [ -> ]
Disable it
Thanks a lot , the scrapper is now working !
