2019-04-22, 21:26
Right now I have a FireTV Stick Gen 2 running Kodi 18.1 Android.
I have the stick using both 5GHZ and 2.4GHZ WiFi-N and same symptoms.
Basically I had to change PCs and reinstall Vista on my file server PC that has my FLV/MP4 files.
On the old PC that was virtually a clone of the current PC, the same Kodi on the same stick had no issues.
Yet now when I play files from the PC on the stick, it randomly after like 2 minutes, freezes the video and the log says "Connection Timed Out" for the SMB connection.
The stick does not do this when I play similar videos from my Ubuntu 18.04 Samba.
Also strangely the Ubuntu's Kodi 18.1 also does not do this behavior playing files from the Vista PC.
I tried changing some typical Regedit settings like TTL and Buffer Size in LanmanServer yet still the same behavior.
I can't seem to figure out what would cause the stick to have issues with Vista, yet the same Kodi version on Ubuntu works fine for the same files.
