Full Version: Error Message: LoadLibrary failed with error 87: Falscher Parameter
Translated with Google:
Hi Guys,
For a few days sporadically the error message "Error Message: LoadLibrary failed with error 87: Falscher Parameter" and TMM Version 2.9.16 are no longer available.
If I confirm the error message, TMM will be closed.
Do you have any idea why this happens?
Thanks and Greetings
Siegfried
Microsoft Windows 10 Pro
Version    10.0.17763 Build 17763
The only library we load externally, is the distributed MediaInfo.
You might want to upload the whole logfile to some pastebin site...
but i doubt, we can do anything about. Must be on your side.
Quick googling suggested to upgrade your AMD drivers (if you have one)
At least, this is what the majority helped.
(be aware of many scam sites, googling this!)
(2019-04-24, 11:23)myron Wrote: [ -> ]The only library we load externally, is the distributed MediaInfo.
Hello and thank you for the answer.
I have not changed anything on the computer, but last Windows updates have been installed and suspect that it depends on it.
AMD driver? Relative to the CPU or do you mean something else?
Sorry I question, but I'm not a computer specialist :-(
