I'm trying to find out how to display discart for my local movies. I'm using Andromeda skin and the fake cdart looks poor. Is there a specific addon i need to use? If i have to downlad all the artwork manually im willing to. I just need to know what to do. Thank you
I responded to you in the Andromeda thread, but you have asked more questions here.
Do you have the files named as
discart or
cdART? They should be named as
discart.
If you go to
Choose Art for one of the movies, do you see all artwork types, or do you see only Poster and Fanart?
If you only see Poster and Fanart, then you need to install Artwork Beef add-on and it will load all your image files into Kodi for use by the skins...
https://forum.kodi.tv/showthread.php?tid=258886
Adjust your settings, then let it run and it will check each movie for local artwork. You can also nominate to download any missing artwork and save it to your movie folder.
aaronmac89
I removed your other posts from Andromeda thread. I don't want to have two separate conversations about the same thing.
In answer to your question, Artwork Beef will download that all for you once set up correctly.
If you have some local artwork, then save it in the movie folder, next to the movie file. You can check correct naming here...
https://kodi.wiki/view/Movie_artwork
Artwork needs to be in the folder
before it is scraped into the library. Adding it after won't work, so you will have to delete it from the library then rescrape the movie back into the library
(2019-04-24, 11:22)Karellen Wrote: [ -> ]I responded to you in the Andromeda thread, but you have asked more questions here.
Do you have the files named as discart or cdART? They should be named as discart.
If you go to Choose Art for one of the movies, do you see all artwork types, or do you see only Poster and Fanart?
If you only see Poster and Fanart, then you need to install Artwork Beef add-on and it will load all your image files into Kodi for use by the skins... https://forum.kodi.tv/showthread.php?tid=258886
Thank you very much. Artwork Beef sorted it out.
Great!!
Thread marked solved.
