Full Version: ArgusTV Addon disabled after todays v19 alpha installed (25th Apri)
Hi
I'm trying out the latest v19 alpha dailies and noticed ArgusTV is deemed incompatible and disabled. Does anyone have an idea if this is a short term issue and will be fixed?
Same thing happens with PVR IPTV Simple. Cannot be enabled or updated. Well, some breakage is to be expected with alphas, let's hope the add-on maintainers update their add-ons quickly.
(2019-04-25, 20:06)Screech Wrote: [ -> ]Argus TV Addon has changed
https://github.com/kodi-pvr/pvr.argustv/...ac348eb444
Great, really pleased to see its still being maintained,  as have tried others repeatedly but still come back to ArgusTV
(2019-04-25, 23:52)i0zjh02 Wrote: [ -> ]
Well, 'maintained' is not exactly the right word. The addon has no active maintainer for a long time. All I do is to keep it building as long as possible. But without a maintainer the next bigger functional pvr addon API change will kill that addon for sure.
(2019-04-26, 08:00)ksooo Wrote: [ -> ]
Anyway, thank you @ksooo for keeping this up for a while! I was hoping that timeshift will be fixed.  There was a pvr addon API change in v18.
Thanks @ksooo for your work.
PVR addons are still c++ only right?  If they were Pyhton based, I'd be happy to have a fair crack at this....
Thanks again for the update, do you know when the updated client will be in the Kodi repository (still incompatible at the moment as is the other one I use - DVBViewer)?
Cheers
(2019-04-28, 12:21)i0zjh02 Wrote: [ -> ]
Cheers
We currently have some issues with building binary addons on Windows. For all other platforms the v19 addons are available, though. No idea when the build issues will be solved. Keep in mind, v19 is in pre-alpha state.
Please,How do I install this
Thank You
