Full Version: mark episodes already seen in Android MQ7
Hello
I have a zidoo box under KRYPTON with the skin MQ7 and I can not seem to have the episodes of the TV series already read which is why? while the same configuration under windows 10 puts me an indication when the episode was seen
Thanks for your help
Mike
It's something in Kodi probably, try press W above the item and check if solve.
Yes it works !!
thanks again one question is there another keyboard shortcut that indicates if the episode is not finished? because under windows 10 if you watch an episode and stopped after 10 minutes we see next to the episode that it is start but not finished
thank you for your help
Olivier
Only in widgets - In Progress
okay but how does one display it?
