I'm having real issues with kodi 18.2 on my Nvidia Shield, whenever I play any content from my NAS the video and audio freezes then playback stops shortly after starting to play (around 30 seconds or so)
My log file is here :
http://paste.kodi.tv/dirucibizi
I've tried disabling hardware acceleration, but it makes no difference
(2019-04-28, 19:38)PCArcade Wrote: [ -> ]I'm having real issues with kodi 18.2 on my Nvidia Shield, whenever I play any content from my NAS the video and audio freezes then playback stops shortly after starting to play (around 30 seconds or so)
My log file is here : http://paste.kodi.tv/dirucibizi
reply to enable subscription as I forgot in the initial post (sorry)
(2019-04-28, 19:38)PCArcade Wrote: [ -> ]My log file is here
Apparently your log file is infested with quite a large number of repositories and add-ons that facilitate video piracy.
As per our
forum rules (wiki) you can either start with a totally "clean" setup and see if the problem(s) still arise, or you can find your support from wherever you downloaded these add-ons.
For now, support to your problem is totally halted.
(2019-04-28, 19:55)Klojum Wrote: [ -> ] (2019-04-28, 19:38)PCArcade Wrote: [ -> ]My log file is here
As per our forum rules (wiki) you can either start with a totally "clean" setup and see if the problem(s) still arise, or you can find your support from wherever you downloaded these add-ons.
Thank you, I'd been meaning to clear all that crap out any as I never use it! Having done a clean install the problem is still there however
paste.kodi.tv/gojajukesu
I've done a bit more playing with this to try and see what's happening. I played
https://4kmedia.org/into-the-cave-of-won...d-4k-demo/ from the NAS with a completely fresh install of Kodi to test. within a few seconds the video and sound froze, but the playback didn't stop, 2 minutes or so later playback jumped to the point it would have been at and continued with both sound and video for a few more seconds. The pattern repeated until the video ended.
Log file is here:
https://paste.kodi.tv/itoyayezoj
I notice a lot of ActiveAE - large audio sync error: and guess this is what's causing the issues, can anyone point me in the direction of a fix or some help?
Thanks in advance
Video Info:
Resolution : 3840 x 2160
File size : 785 MB
Duration : 00:08:55
Format : MP4
Codec : H264
Overall bit rate : 12 Mb/s
Bit depth : 8 bits
Frame rate : 24 fps
4K h264 is not a very common combination. I'll try and test it on my Shield tomorrow, and create a h265 version for comparison.
(2019-04-30, 22:14)Klojum Wrote: [ -> ]Code:
Video Info:
File size : 785 MB
Duration : 00:08:55
Format : MP4
Codec : H264
Bit depth : 8 bits
Frame rate : 24 fps
In fairness the codec seems not to matter, this is happening on every single video I've tried
Disable passthrough, set speakers to 2 channels and provide a new log for the same file, please.
Disabling MediacodecSurface in that combination (still 2 channels, PT disabled) makes it work, right? (Leave alone some stuter, that you will see from the SW decoding).
I just tested from my NFS server your 4K mp4 file on my simple Shield TV (v7.2.3) setup, no AVR, just the TV, and I didn't notice any stuttering throughout the video. Sorry.
Perhaps you have a network throughput problem?
(2019-05-01, 11:14)Klojum Wrote: [ -> ]I just tested from my NFS server your 4K mp4 file on my simple Shield TV (v7.2.3) setup, no AVR, just the TV, and I didn't notice any stuttering throughout the video. Sorry.
That is odd, thanks for all your help, I will keep investigating...
