Full Version: Custom Field (To Use for Renaming)
Could you consider adding a custom field, and a corresponding token for the renamer to access that field?
I would like to have the ability to preface folder names for specific movies (in this case, Marvel Cinematic Universe) with a token MCU01, MCU02, etc, as that will faciliate sorting the movies in proper order for a Kodi playlist. Sets are already being used (Iron Man, Captain America, etc), so that is not an option.
Currently, I have manually added the appropriate prefix to the folder names, but the problem is that it requires remembering never to rename the movie with the renamer. Putting the info into a field will avoid this problem.
Thanks, Carl.
we have a fr for an additional notes field -> could this solve your requirement too?
(2019-05-03, 10:13)mlaggner Wrote: [ -> ]we have a fr for an additional notes field -> could this solve your requirement too?
If the note field has a token to use for the renamer, then yes - that would work perfectly.
Thanks, Carl.
Just curious if there is any update on this feature. It would be pretty useful right now, as my manually-renamed movie folders did get automatically renamed.
Thanks, Carl.
Thank you so much for adding this feature - it works perfectly on my end!
Cheers, Carl.
