Full Version: read from strings.xml
Is there a way to have a skin read and display strings from skin.xml?
A bit like in the credits visualisation on the xbox version?
Would be handy to display the version number of the skin for example.
http://forum.xbmc.org/showthread.php?tid=27892
if you skin is not in the svn, revision is useless, and i don't know how it will work. but the bat file does add skin version also. link is in the last post
Ah cool, haven't seen that one. That should be perfect Smile
cheers
btw, when I said skin version I actually meant a revision number for the skin, not the "2.1" skinning engine version. bad choice of words
